Results 1 to 8 of 8
Thread: Want a second opinion
    May 2015
    Northbrook, IL
    18
    I opened up my in ground pool last Thursday. The pool company put in 8 gallons of chlorine to shock the pool.
    I added another 8 gallons on saturday, but water is still cloudy.
    Here are the readings from the pool shop
    FC 0.71
    CC 1.2
    PH 7.3
    TA 92
    CH 140
    CA 5
    They said drop another 12 gallons of chlorine in there to shock it some more.
    Is that what you guys recommend as well?
    Thanks.
    23,000 gallon in ground vinyl chlorine pool
    hayward pump and sand filter with polaris booster pump
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Want a second opinion
    What is your CYA? Is that where you say CA 5? If it is, it needs to come up to at least 30. I highly recommend you get a TF 100 test kit and don't rely on pool store readings. Your CC is also high. How does your water look?
    Wanted to add that you need FC. Use PoolMath to see what it says on how much bleach to add, but if your CYA is 5 you will continue to burn through bleach
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,186
    Around here much you will find that not much credence is given to pool store testing. While you would think that a "professional" would be the best, unfortunately in most cases it is quite the opposite. Between employees who blindly trust the word of chemical sales representatives and high school kids working in the pool store for the summer you end up with poor results from their testing. In my case two different pool stores told me my CYA was "fine", around 70 or 80. When I tested myself I found it over 200.
    They "usually" don't mess up the FC & pH too bad, so like Lisa said you need chlorine in the pool. But, you need something more important - keep reading......
    To follow the pool care methods taught here you need to arm yourself with the knowledge and tools necessary to care for your pool.
    The knowledge is condensed in the Pool School link at the top of every page. It is a great community here, but we do ask that you read and try to understand the information being taught. Questions are always welcome and folks will try to direct you and teach you the methods.
    The tools are not limited to the brushes, vacuum hoses and other stuff you use around the pool, but include the most important item - one of the recommended test kits. You can buy a kit at a pool store, but again the pool store kits generally won't cut it. To effectively practice the TFPC methods, the FAS/DPD chlorine test is essential. All these kits contain that test while very few other kits do. Think of it this way, do you see a doctor blindly prescribing drugs without seeing the patient or having tests run? Here at TFP we are going to ask for photos so we can see the condition of the water and are going to ask for a full set of test results.
    Support the site
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    I echo the Taylor kit suggestions, but think you need some chlorine asap. Go to pool math above and plug in what you have so it can tell you how much liquid chlorine to add till your kit comes in. Wait for your kit before adding cya as their numbers could be way off.
    Based off of those specs, I'm guessing you need a gallon of 8.25% bleach to be safe.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I'm a big believer in High FC to clear a pool that needs it, but I feel strongly that the advice of putting in 12 gallons is careless. Especially without them knowing what the Cya level is. I think you care whether or not your liner gets bleached out don't you?
    Essential Links:
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Quote Originally Posted by Patrick_B View Post
    Absolutely agree.....just put enough to keep you around 3 to 4 fc until your kit comes in. I'm thinking that is a gallon.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Quote Originally Posted by rocbuddah7 View Post
    Thanks.
    Nope. 12 gallons of 10% chlorine will raise FC in a 23k gal pool by 52ppm. And that is on top of the 70 ppm already added by the previous 16 gallons. That takes shocking to a whole new level!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yes, I didn't do the math, but it was obviously too high to suggest doing anything more than testing properly before taking further action. This is what we suggest doing first.
    Essential Links:
