pH keeps going up
Hi all!
I recently finished SLAMing the pool, but my pH keeps going up quite high every day. I read on TFP that it's due to the high TA. I started with TA 300 a few weeks ago, and now I'm down to 200.
What level should I aim for? I've got a tiny AG pool - 5300 gal
I had a pH of 8+ day before yesterday, but 2 doses of dry acid got it down to 7.2 last night. It's 7.8 right now (the pump was running all night because my husband forgot to turn it off).
This morning's readings:
pH 7.8
CYA 40
FC 16.5 (it was up to 20 during shocking process, just finished 2 days ago)
CC 0
TA 200
We do not have a SWG right now.
At that high TA level, your pH will also rise faster than with a lower TA. Once you can reliably test pH at lower FC levels, just keep dropping the pH to 7.2 when it gets above 7.8 and eventually the pH rise will slow once TA gets to a lower level through the acid additions.
