Results 1 to 12 of 12
Thread: pH keeps going up
    Mar 2015
    Lake Charles, LA
    26
    pH keeps going up
    Hi all!
    I recently finished SLAMing the pool, but my pH keeps going up quite high every day. I read on TFP that it's due to the high TA. I started with TA 300 a few weeks ago, and now I'm down to 200.
    What level should I aim for? I've got a tiny AG pool - 5300 gal
    I had a pH of 8+ day before yesterday, but 2 doses of dry acid got it down to 7.2 last night. It's 7.8 right now (the pump was running all night because my husband forgot to turn it off).
    This morning's readings:
    pH 7.8
    CYA 40
    FC 16.5 (it was up to 20 during shocking process, just finished 2 days ago)
    CC 0
    TA 200
    We do not have a SWG right now.
    5300 gal, AG vinyl, .95HP 28651EG Intex Krystal Clear 3000 GPH Sand Filter Pump
    TF100 - test kit
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: pH keeps going up
    Your ph won't be accurate with your FC above 10ppm.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    Recommended levels can be found here:
    http://www.troublefreepool.com/conte...mmended-levels
    PH readings can be inaccurate (reading high) when your FC is above 10. You may want to wait until the FC is 10 or less and test PH again before making any adjustments.
    (Azgirl beat me to the answer)
    Steve
    32 X 16 inground, 17260 gallons, Vinyl Liner, Triton II TR-60 filter,
    Sta-Rite 1hp pump Model #MPRA6E-147L, CircuPool SI-30 Plus SWG, TF-100 Test Kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    That is correct. The pH reading is invalid above FC 10 and up. Don't adjust or retest until it's below 10 FC.
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Here is a little more detailed info on saltwater balance. Water Balance for SWCGs
    Mar 2015
    Lake Charles, LA
    26
    Oh wow.
    Thanks! I can't believe I forgot that.
    TF100 - test kit
    Mar 2015
    Lake Charles, LA
    26
    Additional question: my pool is in direct sunlight all the time, so should I aim for a higher level of CYA? I read elsewhere that 60-70 might be better, even for a pool without a SWG
    TF100 - test kit
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    At that high TA level, your pH will also rise faster than with a lower TA. Once you can reliably test pH at lower FC levels, just keep dropping the pH to 7.2 when it gets above 7.8 and eventually the pH rise will slow once TA gets to a lower level through the acid additions.
    Isolated Spa - 345 Gallons
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by lucimireles6 View Post
    Try it no higher than 60 for a while and see how that does. You can always increase it.
    Essential Links:
    Mar 2015
    Lake Charles, LA
    26
    I will! Thanks for all your suggestions
    TF100 - test kit
    Mar 2015
    Lake Charles, LA
    26
    Quote Originally Posted by JVTrain View Post
    I will do that. Thanks!
    TF100 - test kit
    Mar 2015
    Lake Charles, LA
    26
    I turned the pump off this morning.
    The FC dropped to 11.5. Is that typical? That seems like a huge drop. The surface of the pool is pretty warm since the water wasn't circulating. Should I leave it running and turn the filter off?
    TF100 - test kit
