Thread: Leveling Above Ground Pool and Pool collapse questions
    Mar 2015
    Boise, ID
    1
    So I'm new to this and just put up an Intex 12 x 24 x 52 inches deep pool. I know the pool has to be pretty level. I have mine within about an inch. Then I was reading about the subject and ran into stuff about pools collapsing and failing. Now I'm freaked out that my design is bad. What happens when a pool has a collapse? Are there signs to look for that something is going wrong?
    Here is what I did to build my pool. I used brick pavers for the the base points where the pool frame touches the ground. I made sure those were level with each other. Then I brought in road mix to level it up to the pavers and then I used to sand to cover that with and make the bottom soft.
    Here are some images of my pool. I just want to make sure I haven't done something really stupid, and if I have, how to fix it.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Leveling Above Ground Pool and Pool collapse questions
    It looks good to me, but I am not an expert. My pool is level within 1-2 inches. We have not had problems
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    I think I might fill in between the pavers with more pavers to stop the sand from washing out. That is plenty level.
    Orlando, FL
    690
    I agree about the sand washing out because it always does. If you can, put in some cheapo drainage pipes to route rainwater around the pool. I did not do this and rainwater has gotten under the pool and the pavers have shifted. Live and learn I guess.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Casey's Avatar
    SW PA
    10,428
    Keep an eye on it as the summer progresses. If one side starts to dip out of level, consider redoing the foundation.
    titleistseemore's Avatar
    Jul 2014
    Lodi Ca
    189
    Like the previous post mentioned, just need to keep your base from washing out. I have done this a few times with sand and I have never had it wash out as of yet... I use long galvanized spikes (look like large nails). What I do is put a 2x4 or 2x6 and kinda of make a sand box type frame using the spikes and large washers to hold the wood in place. On my first pool I put the sand on the a tarp and then leveled, once leveled I took the sides of the tarp and folded them up like a diaper and drove the spikes in. It worked great but keep in mind that I only had the pool up for about 7 months or so... but if you place a border in between your pavers you should be ok. The reason I mentioned 2x4's or 2x6's is that you can cut them to length to go in between your pavers or all the way around your pavers? Just a thought on some of the previous things that I have done. By the way nice green grass, I hope you left enough space for the mower ...
    One more thing, I would measure (Which you probably already have) the base depth to ensure that you can measure it from time to time to ensure that you have not lost any of your base ...
    Tim Jacobsen Lodi Ca.
    18'x48" Intex Ultra Frame (5700 Gallons)
    TF 100 Test Kit, Speedstir, & Sample Sizer. Liquidator Installed.
    Hayward C550 Cartridge Filter (55 Sq. Ft.), 1HP Powerflo LX Pump, Pool Rover Jr.
    http://www.troublefreepool.com/threa...uild-Questions
