Results 1 to 8 of 8
Thread: Pump won't prime
    Kidswimin's Avatar
    May 2015
    Madison, WI
    15
    Pump won't prime
    Long time reader, first time poster. I opened my pool this weekend, used a net to get most of the big stuff. Got the pump running, and started to vacuum the leaves and other debris off the bottom. I removed the vac plate from the skimmer basket to empty it, tried to vacuum more, and pump lost prime from sucking air when removing vac. I tried everything (I think) to reprime the pump, and it won't. I blew the lines out with air to see if anything got behind the skimmer basket while emptying. I replaced o-rings on the pump plugs, and resealed all other fittings. I tried to get the pump going with just the skimmer line, just the bottom drain line, and both. Nothing seems to help.
    Any Ideas?
    Dave. 13,000 gal inground vinyl. 3/4 hp single speed. Hayward 300# sand filter. Taylor K-2006 test kit. Pool built in 80's survived tornado in 90's. Recently added (4) 4'x12' solar panels with solartouch controller. New to me 1999 Hot Springs Sovereign tub.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,600
    Re: Pump won't prime
    With the pump unplugged.....can you feel anything that may be jamming up the impeller?
    Kidswimin's Avatar
    May 2015
    Madison, WI
    15
    The impeller spins freely. When I pour water in the basket to get it to prime, I can see it pulling the water I pour in but it doesn't keep pulling.
    Kidswimin's Avatar
    May 2015
    Madison, WI
    15
    I think I found the problem. When pump is off there is a drip coming from the bottom of the band clamp the oring looks good but I will replace. Should I also replace the clamp. Any other ideas
    30,419
    I am not at all sure that is your problem. Are you talking about the band clamp on the pump?
    Kidswimin's Avatar
    May 2015
    Madison, WI
    15
    Yes, the band clamp on the pump. That is the only thing that I can see is leaking. Could that suck enough air to not allow the pump to prime?
    Jun 2013
    Huffman Tx
    190
    yes, most suction leaks are at the connection
    Kidswimin's Avatar
    May 2015
    Madison, WI
    15
    New o-ring same problem. Up next is the shaft seal
