Results 1 to 7 of 7
Thread: stairs starting to rust
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Is it common for stairs to rust? I just noticed mine are starting to, is there an easy fix?
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: stairs starting to rust
    I'm hoping someone has a suggestion on this. The stairs are only 8 months old. Is this a chemistry issue I'm not addressing or just bad stairs?
    May 2015
    Wildorado Texas
    252
    Actual rust is iron oxide. I suspect this is just some kind of rust colored stain. Have you tried to clean it?
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Yeah, I scrubbed it to no avail.
    May 2015
    Wildorado Texas
    252
    Quote Originally Posted by Defgufman View Post
    If you can get the "rust" areas dry, try rubbing some Elmer's Glue on the "rust." If it turns black, it IS iron oxide and is also now neutralized. Acetal Acetate is Elmer's, and it reforms rust. At any rate, if it turns black after curing, it is now easily scraped off the stainless steel and some steel wool to polish after, should finish nicely.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Quote Originally Posted by Red Neckerson View Post
    Awesome....thank you for the idea. Now I have a project for my day.
    May 2015
    Wildorado Texas
    252
    You can buy the Acetal Acetate in gallon jugs at Grainger's it's marketed as "Rust Reformer" and it's great. Turns the rust black, and leaves a great primed surface to paint. Of course, you don't want to paint stainless steel but you get the drift.
