Results 1 to 18 of 18
Thread: Green, Green, Green! Help!
    May 2015
    Alabaster/AL
    9
    Help! Our pool is still green after shocking!
    We we bought our house as foreclosure 9 years ago. Initially, we used tri-chlor and di-chlor, then went to a SWP. Loved our SW pool! Well, cell went bad then board got struck by lightning. Last year, we went back to chlorine for $$ reasons. Pool turned bright orange when opened (shocked) for summer. Got orange out of water, but could not get off liner or anything else. We found info on your site about using citric acid and followed directions. Worked! This year, we went out of town for 1 week. Hadn't opened pool, but was not covered over winter. Came home to green, green pool. Shocked with di-chlor since CYA not high. Wrong idea. Faint orange ring on fixtures and around pool. Yikes! not again. Started researching.
    Today, I decided to SLAM pool. No more tri-clor or di-chlor. Brushed down pool, backwashed. CYA very high, but read where someone had theirs around 200 and still used bleach to rid algae, ours is 120. Used FC -CYA chart and figured need 7 bottles, 2quarts of 121 oz, 8.25% bleach. Brushed pool again, backwashed, added 8 bottles of bleach. Waited 30 minutes - tested FC. Yikes! I could not get the test to turn back to white. By drop 72 of R-0871 the color turned dart violet, well, kept counting and swirling. I got to drop 90 and stopped. Ridiculous to continue.
    At this point, I don't know what to do.
    I would be so appreciative of any recommendations!
    Found your site last year, it is awesome!
    last test with Taylor kit late last night
    CYA - 120,
    FC - 8,
    CC- .4,
    PH- 7.4,
    TA - 40
    19,000 gal, in-ground, vinyl liner, deep end 8 1/2ft, shallow end with steps, bottom drain, 1 hp motor, sand filter, large trees near pool.
    38,295
    Re: Green, Green, Green! Help!
    Welcome to TFP!
    How did you get the CYA of 120ppm? You really should replace water to lower this first.
    Also are you using a 10ml water sample for the FAS-DPD chlorine test, so each drop is 0.5ppm?
    May 2015
    Alabaster/AL
    9
    Thanks for your reply!
    I had read on a thread that it was recommended to use 1/2 pool and 1/2 tap water when reading was too high to read. I got 60 so multiplied by 2.
    For the chlorine test I used 25ml of water.
    We initially drained pool down to first step and got the CYA down to the high end of normal range. Then my husband shocked with Di-chlor and we were using tri-chlor tablets. Once he shocked - yikes!! it spiked again.
    Draining again, wow, I am afraid to see our bill, but if must... guess we will. Hate to waste the chlorine I just dumped in there.
    Your thoughts?
    Thanks!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Hi CRC, welcome to the forum.
    That Dichlor is raising your Cya level, so you ought to consider another form of Chlorine. You need to SLAM your pool. Take a look at the link in my sig line for the info. While your browsing, take a visit to the ABCs in pool school to get started. It will help.
    Essential Links:
    May 2015
    Alabaster/AL
    9
    Thanks Patrick_B!
    Thanks to TFP forums we realized that Tri-chlor and Di-clor was our high CYA problem!
    We started SLAM today after reading your link couple of days ago. Jason recommended draining pool down to lower CYA (we just did this 2 weeks ago but made the mistake of shocking with Di-clor after refilling - ooops!!!). Live and learn. Guess tomorrow I should start vacuuming to waste water and begin draining again. I will also visit the ABC's of Pool Chemistry!!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Hey, good deal. That's a plan, as you don't want to slam with that level of Cya. If you run into questions, don't hesitate to ask. We'll be here to help as long as you feel like learning. Just let us know.
    Essential Links:
    Casey's Avatar
    SW PA
    10,444
    Welcome to TFP.
    Sometimes we learn from our biggest mistakes n sometimes not. Reading Pool School will help you immensely understand what and why things were happening in your pool. You also seem to have a metal problem.
    May 2015
    Alabaster/AL
    9
    Appreciate it!
    Thanks for the help!
    May 2015
    Alabaster/AL
    9
    Thank you Casey.
    Yes, last year we became aware of the metal problem. We started researching on TFP. Found out that if your CYA gets too high and you don't keep on eye on the other levels - the metals in the water will leach out and attach to surfaces. At this point, not sure if rust or other. If rust, guess it is coming from somewhere we are unable to access to fix. Does that mean we will have to start adding metal out products to maintain? We tried putting a camper filter on our hose last time we drained down and filled (wondered if something in our fill water). Don't think it made a difference.
    What are your thoughts?
    Thanks for your time!
    Casey's Avatar
    SW PA
    10,444
    You'll need a sequesterant. Do you have well water?
    May 2015
    Alabaster/AL
    9
    We have city water supply.
    No pool heater.
    Will citric acid treatment be the only way to remove stains?
    Apr 2013
    Eatonton Georgia
    145
    Don't feel bad.... I once poured five bags of shock, over about three days, into my 7000 gallon AGP and wondered why it wasn't killing the algae. I never realized that most shock had CYA in it till I read it here. I think those bags of shock can be OK if you want to raise your CYA in small increments without going to the expense of buying stabilizer but otherwise I'd stay away, from what I've been told.
    18ft. diameter, 48 inch deep Sharkline Reprieve AGP, 7000 gallons, Intex 14 inch sand filter with 3/4 H.P. 2,150 GPH pump, Intex SWG
    TF-100 test kit
    May 2015
    Alabaster/AL
    9
    Yes, I think we have learned our lesson with Tri-chlor, Di-chlor and relation to CYA. Looks like we will be using the BBB method from now on!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    We don't refer to it as BBB anymore. What we do (TFPC) evolved from it, but we stopped using the term. So many people assume you need all three products, which is rarely the case.
    Essential Links:
    May 2015
    Alabaster/AL
    9
    Patrick_B,
    That is good to know.
    Our pool is now blue and very cloudy. Yesterday, it was blue and cloudy after the night before adding 8, 121 oz jugs of 8.75% bleach. I cleaned skimmer, backwashed and vacuumed to waste over and over again until water was almost to second step. Then filled pool back up.
    Here are my readings from this morning (Taylor kit).
    hardness - 120
    FC - 17
    pH - 7.4
    TA - 80
    CYA - 70
    Do you recommend bringing levels to normal range at this point? I am going to brush and vacuum again (just to be safe). Would bringing the pool to normal levels take care of the cloudiness?
    Thanks for your help!
    38,295
    If the water is cloudy, you should still be following the ShockLevelAndMAINTAIN Process. You FC is far too low.
    May 2015
    Alabaster/AL
    9
    Ok. Thanks!
    I will use the FC-CYA chart and then Pool Math to figure how much I need.
    Is it ok to add the required bleach to continue SLAM during the day while sun is on the pool- or will this eat up the bleach/chlorine? There will be partial shade over pool by approx 2:00 - safe then?? Or is it best to wait till night?
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Continue SLAM. You want your FC to stay at scock levels as much as possible during a slam
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
