Results 1 to 7 of 7
Thread: Painting a pool
    May 2013
    Virginia
    75
    Painting a pool
    First let me say I've read dozens of threads that say don't do it. However, our pool is already painted. It is currently emptied due to extensive repairs to our sinking-on-one-side-patio (the pool is built into a giant retaining wall into a steep hill). While power washing and cleaning up the pool, I noticed there were a 4-5 quarter size chips of paint flaked off on the bottom, some with plaster exposed.
    My questions are:
    1. Has ANYONE painted their pool and had it last more than 2-3 years? Our pool had been neglected for at least 5 years (renters living in the house before us) yet the pool and paint were in good condition when we moved in. If so, what kind of paint did you use?
    2. If we decide to paint, I would like to paint it a sand colored paint. I love the look of a more tropical soft blue pool. However, our pool is on the smaller size (20 ft across with depths of 3-5 ft). Will it look like a beige hole in the ground?
    Any comments or advice is welcome.
    10,000 gallon inground, gunite, 500lb sand filter. Brand new to this pool thing.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Painting a pool
    No, as long as it is a lighter, more white-ish color ,it will look like shallow ocean water. More bluish. The more tan-brownish you get, the more green the hue. Paint is good for about 2-3 years tops. Good luck on your project!
    Essential Links:
    Oct 2014
    Columbus, Ohio
    23
    Re: Painting a pool
    Painting a pool is 70% Preperation, 25% quality materials, 5% a guy with a roller.
    Be sure to perform a 3 step chemical wash (tsp-acid-tsp) for your surface I would use a gunzite primer from Olympic and also Olympic epoxy paint.
    If you do this and do it to spec, you will get a solid 5-6 seasons out of your pool with proper chemical balancing ofcourse.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Painting a pool
    Pretty consistently, we hear reports of paint peeling/chiping in 2-3 years. Your mileage may vary. Let us know how it turns out, and show us some pics when you're all done. Would love to see it.
    Essential Links:
    Mar 2015
    Tulsa/Oklahoma
    68
    Re: Painting a pool
    My neighbor across the street , who has since sold the house, said every spring he would drain his pool and paint it with basement paint. I personally thought that was a bad idea and can't imagine how many layers of paint are on there if it were to ever need to be removed and replastered. Asked my PB if they painted pools and he said he used to have a guy he would contract to do it, but now he just tells anyone that asks that they don't do it. Also said its a big pain to remove it for a replaster. He charges in neighborhood of 2k just to sandblast it off. Good luck if you decide to paint. I imagine its the cheaper option in the short run.
    1972 - 22,500 gallon, In-ground Kidney shape Gunite pool built by Fiesta pools (2015 remodel), Sta-Rite sand filter Model 9462404 side mount ( Triton II TR60 is newer Equivalent), 3.1 sq ft., Pentair 011018 IntelliFlo Variable Speed Pump, Leslies Coppertherm (Raypak) PL 260AEN 260,00 BTU Heater, Anchor Defender Mesh Safety Cover, Taylor K2006 test kit, Dolphin Z5 Robotic Cleaner
    Casey's Avatar
    SW PA
    10,421
    Re: Painting a pool
    Paint never last more than a season or 2.
    Nov 2011
    Moberly,MO
    1,010
    Re: Painting a pool
    With proper preparation and care paint can last. I have a commercial customer that made six years. This spring we are sandblasting and starting from scratch. One of the biggest keys to paint lasting is doing what the label says. Follow directions. Do not shortcut it.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
