Thread: Question about CYA
    Question about CYA
    My CYA reading shows zero. I poured 5 lbs in a sock yesterday and it dissolved, shouldn't I have some sort of reading by now? Thanks
    18x37 IG 22,500 gallons...Vinyl Liner...Hayward EC-65 DE Filter...Hayward 1HP Super Pump...Aquarite SWG...TF-100 test kit.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,195
    Re: Question about CYA
    Quote Originally Posted by harpfamily View Post
    Not necessarily, it can take up to a week to register on a test.
    Support the site
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    Not necessarily
    As it says in Recommended Pool Chemicals
    Solid cyanuric acid can take up to a week to fully register on the test, so it is best not to test the CYA level until one week after adding some.
    Pool math says 80 oz of stabilizer will only raise CYA by 27. Most testers won't read below 20, some below 30. Even if the stuff is 75% dissolved, you still won't get a reading.
