Results 1 to 8 of 8
Thread: Greets from Canada's Wet Coast!
    May 2015
    Abbotsford, BC
    17
    Howdy all,
    Not ENTIRELY new to pools, but still pretty green (pardon the pun) to pool maintenance. When we bought our house a year ago in December, the pool had already been closed down for the winter, and in the spring, we called their old pool guy to come open it up for us. By fall he seemed to have dropped off the earth, so we did a half-baked job of closing it down ourselves... now we've almost got it ready to go, about 90% through the chemical treatments recommended by our water test. Figured it would be a good idea to start learning more about taking care of it through the year!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,002
    Re: Greets from Canada's Wet Coast!
    Another one from Canuckistan! Welcome, eh?
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    Do you have a GOOD test kit? Around here we all like the TF-100, but I'm not sure they can be shipped your way. Another option is the Taylor K2006 (with the all important FAS-DPD chlorine test) so you'll get the most accurate tests and you'll be able to determine exactly what your pool needs. AND what it doesn't need, which is just as important.
    First step is to read the Pool School articles (above right link) and get that test kit. Stay away from pool stores whose main goal is to sell you products.
    May 2015
    Abbotsford, BC
    17
    I'll look into those, thanks. We just have the little bottle of test strips for now... we have a couple different local stores who sell the same BioGuard lines and have the BioGuard test systems. So far neither has been any kind of high-pressure sales, although one is generally a lot cheaper than the other.
    "After a time, you may find that having is not so pleasing a thing, after all, as wanting. It is not logical, but it is often true."
    Pool: 80,000l (21,000 USG) 32'x'16' in-ground concrete with vinyl liner
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    The TF100 can't be shipped to Canada unfortunately, but the K2006 is avalible through a certain supplier. Sorry I don't remember the name.
    Welcome again, and enjoy the forum.
    Essential Links:
    Casey's Avatar
    SW PA
    10,444
    Welcome to TFP.
    The ABC's of pool water chemistry is an excellent article to start with pool school.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,492
    Welcome to TFP!
    Here is some introductory reading from Pool School.
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    What we need to know to answer your questions
    May 2015
    Abbotsford, BC
    17
    Quote Originally Posted by Patrick_B View Post
    Thanks for the warm welcome, all!
    Fortunately, I live about five minutes from the Sumas crossing, and have a friend who lives in Lynden, WA, ten minutes down the road from there. Shipping isn't a problem
