Results 1 to 14 of 14
Thread: Help with setting the pool up for Winter
    Dec 2014
    Auckland, New Zealand
    34
    Hi all,
    After some help with how to set up my pool for this coming winter.
    Reading a bit on here, people seem to empty out lines etc but as we don't get to freezing point over Winter I don't think that's necessary here?
    We turned the heat pump off 2 weeks ago and the water temp is now down to around 65deg.
    I have reduced the pump running time right down to 4 hours per day, running from only midday to 4pm each day.....however I am now starting to get some algae build up along the sides even though my Chlorine levels are quite high? I think I will change the setting for the pump to run 3-4 hours in the am and another 3-4 later in the day so its not sitting still for long periods.
    My test numbers yesterday before the pump turned on were:
    FC 5
    CC 0
    Ph 7.2
    TA 20
    Cya 0 (My SWG doesn't recommend any CYA in the water?)
    CH 50
    Salt 3000
    With the above should I be getting any algae? I would have thought with FC of 5 I should have been fine. My pool builder told me I need to have the salt level at around 3200, last week it dropped to 2800 and my SWG told me the level is low. The SWG manual tells me salt level should be 4000, guessing I should do as the manual says?
    A few questions above I know.....but any advice on how I should have things set would be great.
    Keen to have things sparkling, at minimum costs over winter.
    19K gal Fibreglass, Astral Pool Viron eQuilibrium Auto SWG, 3 Speed Astral Pool Viron Evo Pump, Astral Pool RX360 glass filter
    Starting off the New Zealand Summer!
    Jan 2012
    'burbs of Augusta, Georgia
    7,364
    Re: Help with setting the pool up for Winter
    If your salt level is too low, perhaps the SWG is only working sporadically or not well enough to keep the chlorine up. Do you plan on covering the pool-this will help you not lose any chlorine as fast, since you don't use CYA. I have never heard of a SWG advising such. What ever chlorine you're making is going to burn off and allow that algae to take hold if you don't put some in soon.
    If you currently have algae you need to SLAM the pool, either now and be done or decide to ignore it over the winter and start when the weather warms again. But delaying will mean a much larger mess to deal with.
    Dec 2014
    34
    Quote Originally Posted by YippeeSkippy View Post
    But with the FC level sitting at 5, even after the SWG had not been running for around 20 hours, shows that Chlorine levels are fine?
    Dec 2014
    34
    BTW.....I see you are in Augusta!! I am looking to come to your neck of the woods to see the Masters next year....any tips on securing hot priced tickets?
    Jan 2012
    7,364
    Quote Originally Posted by Cuzziebro View Post
    Cash. A lot of cold hard cash. I've been for the past 10 years but sadly couldn't attend this year (health reasons) and I missed my beloved pimento cheese sandwiches on the coarse with a cold one. It is sort of a ritual.
    Dec 2014
    34
    Righto....update:
    I have added more salt, which has my salt level up to 3600. SWG manual tells me it should be around 4000, but I haven't read of anyone been that high?
    Levels are now:
    FC 6
    CC 0
    Ph 7.5
    TA 20
    CH 50
    Salt 3600
    Still have algae in pool and FC has been 5-6 the whole time?
    Time to SLAM? Just not sure how I have got the Algae when the FC has never been low?
    I want to shut the pool up for winter, but don't want to do it while there are tinges of green in there.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I would say if you see algae it is time to SLAM
    You may want to lower PH to 7.2 first.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Dec 2014
    34
    Quote Originally Posted by Azgirl71 View Post
    Yep think I might have to go that route.....liquid chlorine is so expensive here, around US$35 per 5Gal container....and I can't find any bulk bleach.
    Dec 2014
    34
    Argh.....went to pool store today to pick up the Liquid Chlorine, the have 20L 15-20% so good and strong. When I told them I have algae even though my FC hasn't dropped below 5-6 they said I need an Algaecide, as my Algae must be resistant to the chlorine.
    I think I know the answer.....ignore and SLAM?
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,575
    You got it! SLAM time for you.
    If I have to go to the pool store to get something I get what I need and move on. I do not talk to them except to say "HI!" and "I got what I need"
    Kim
    Dec 2014
    34
    Also....I am not sure on this CYA thing. Even though my SWG manual tells me no need to add any, should I get it up to 50 or so before I start the SLAM to ensure no FC is killed of by the sunlight in the process?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I would get your CYA to 30 for SLAMing. You'll use less bleach at that point due to the lower shock level you need to maintain. Your shock FC level would be 12. You will still lose some FC to sunlight regardless.
    After your done SLAMing raise your CYA up to 70-80 for your SWG.
    Also make sure you run pump for a good 40-60 min's before you take any tests to insure your water is mixed well.
    Jeff
    Dec 2014
    34
    Done, will lift CYA to 30, lower pH to 7.2 and go for it. Will start this weekend when I am home during the day.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Sounds good. The weekend is the best time to start so you can baby sit it !
    Jeff
