Thread: Need help with connections!
    WitchyD's Avatar
    Jun 2014
    Tennessee
    10
    I have these two products
    image.jpg(Intex Surface Skimmer Replacement
    Strainer Hose Adapter)
    They are both approximately 1 1/2" diameter (a little less on inside, a little more on outside).
    I want to connect them to each other, and cannot for the life of me find a contraption to do this!
    Any ideas?
    22'x52" 10,472 gallon AG Intex Ultra Frame pool on a sand base, Intex Sand Filter 3000GPH Pump, Intex Krystal Clear Saltwater System, Pool Devil Pro Skimmer
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Need help with connections!
    Can you clarify a little? You're saying the hose is too small to fit over the adaptor nipple?
    If they're close to the same outside diameter, go buy a short chunk of rubber hose at the hardware store or auto parts store. Or make something by slicing a section out of a bicycle inner tube that can stretch over. If there's a bike shop in town, they probably have a whole bunch of thrashed tubes in the trash cans.
    Intex equipment is always a slightly different size than any other brand. Trying to mix Intex stuff with other brand equipment requires adapters.
    WitchyD's Avatar
    Jun 2014
    Tennessee
    10
    The hose has hose cuffs on both ends that we don't want to chop off. I found this YouTube video with the perfect part if anyone else has this issue: http://youtu.be/YfLnsQnt5mc
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    that looks like a great idea! Necessity is the Mother of Invention!
    Divin Dave,
