Results 1 to 11 of 11
Thread: Pump motor replacement
    May 2014
    Frisco, TX
    18
    Hi All, I need some advice on finding the right replacement motor for my pool pump which died yesterday.
    The pump is Hayward Super II Pump, model SP3015X202AZ, it uses 2 speed motor. None of the local stores carry those, so I guess I will have to go to ebay. However, I wanted to check a couple of things before ordering one.
    1) The tag one the pump says it is 2HP, but the motor is 1.5HP, model SPX1610Z2M(S). Would it make sense to upgrade to a 2HP motor or just go with the exact replacement?
    2) Two speed motors seem to be harder to find nowadays. What if I go with a single speed? Or upgrade to a variable speed one? Any pros/cons besides the obvious difference in the electric bill?
    32k gal IG plaster pool w attached spa and waterfall feature, Pentair IntelliFlo VS pump, Pentair MasterTemp 400K BTU NG heater, Hayward C5025 SwimClear cartridge filter, IntelliTouch control panel w ScreenLogic2 interface.
    38,251
    Re: Pump motor replacement
    You have to consider the service factor of the motor too. Look at the SF*HP and match that. I would recommend staying with the 2 speed. Remember to replace the shaft seal too.
    May 2014
    Frisco, TX
    18
    Thanks, I forgot about SF, will take it into account.
    Yes, I got a set of seals today, just need to find a motor now.
    mas985's Avatar
    Pleasanton, CA
    11,737
    The SP3015X202AZ is an up rated 2 HP which is the same as a full rated 1.5 HP which is probably the motor that is on there now. You can actually use either one.
    Mark
    May 2014
    Frisco, TX
    18
    Yes, the one that just died was 1.5 HP.
    The pump manual parts list calls for SPX1610Z2M(S) motor. Here is what I found on ebay: Hayward 1.5 HP, 2 Speed Motor Replacement Northstar - HAYSPX1610Z2MNS
    It looks like the right one, but I am not sure what the difference in last three letters mean: M(S) vs. MNS.
    mas985's Avatar
    Pleasanton, CA
    11,737
    That is a 1 HP full rated motor despite what they are telling you. A 1.5 HP full rated (2 hp up rated) would be a 1615. The last two digits are the FRHP.
    Mark
    May 2014
    Frisco, TX
    18
    Ah, yes, 1615 of course. I was looking at the wrong line of the parts list.
    Thank you!
    May 2014
    Frisco, TX
    18
    Update: new motor arrived yesterday. Since I took the pump apart anyway, I decided to replace all seals, impeller, impeller ring and diffuser, which were showing some wear. Installed new parts without any problems, the pump is running like new.
    Thanks everyone for advice!
    38,251
    Aug 2014
    Shallotte, NC
    693
    Probably the single most important number on the data plate is the Frame Size. Also important is the part number, HP, and RPM...... Hayward does not make these pump motors, it appears that Century does. You can probably buy the same thing cheaper....
    May 2014
    Frisco, TX
    18
    Yes, it is a Century motor with Hayward logo on it. I don't know however, if they sell a "generic" version of this motor with the same characteristics.
