Thread: Need for Spa Blower
    May 2015
    Lucas, Tx
    2
    Question Need for Spa Blower
    I have a question on the need for a spa blower. My son recently had a pool built and he used a different builder than the one I used. Both builders have good reputations and have been in business for many years. I noted my son had a piece of pool equipment that I don't have. After research I discovered it is a spa blower. I do not have a blower, my spa operates from the pump only. The water pressure coming out of the venturis on my pool is comparable to the pressure coming out of my son's venturis. However, my son's spa generates considerably more water action/bubbles than mine which I assume is due to the blower. Why do some pool builders install a blower and some do not? Is it merely a cost issue or are there other reasons to exclude a blower and operate the spa totally from the pump? Is the water action/bubbles for effect/show only so to speak? Any comments would be appreciated.
    18,000 gallon in ground, saltwater pool with spa. Pentair Clean and Clear filter, Pentair Intelliflo variable speed pump, Pentair Inellichlor chlorinator, Pentair Sta-Rite heater, Polaris 280 cleaner.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,055
    Re: Need for Spa Blower
    My spa has a blower with air holes in the floor of the tub. Yes, it does generate a whole lot of bubbles. I suppose if someone wanted to keep the surface rolling so nobody could see their swimsuit body beneath the surface, it's a good thing. Otherwise, I find it does nothing but a)make a lot of noise like a leafblower and b) inject a lot of cold air into the hot water, cooling it and forcing the heater to work extra hard.
    I suspect it's mostly a high profit upgrade for the builder. You aren't missing much by not having it.
    38,475
    With properly designed spa plumbing, a blower should not be necessary.
    May 2015
    Lucas, Tx
    2
    Richard,
    You are correct, when they were building my son's pool, I also noted that he has a hole in the center of his spa floor in addition to the two drains. I only have the two drains in mine. I wondered what the hole was for, now I know. Thanks for the reply.
    John S.
