Thread: Polaris 360
    Sep 2007
    Guelph, Ontario, Canada
    60
    Polaris 360
    I found a reasonably priced Polaris 360 for sale, and I'm looking to replace my vacuum cleaner.
    I have a 1HP pump with 3 return lines. The filter gage runs around 12 psi.
    From what I understand, 1 of the returns will get a quick connect to install the cleaner. The other 2 returns will likely need pressure regulators or plugs installed.
    I expect to clean the pool once or twice a week. Are the pressure regulators or plugs necessary to get the correct pressure, intended to be left in when the cleaner is not working? Will this significantly reduce the water circulation? or skimmer effectiveness?
    Thanks
    Carl Schnurr
    Pool: 96,000 litre, vinyl liner, 1 HP pump, sand filter, Aqua-rite SWG, Hayward e.vac, installed 2005
    Spa: La-Z-Boy 'Relieve', 1300 litre, acrylic, with ozonator, installed 2017
    Test Kit: Taylor 2005C
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Polaris 360
    I believe these are designed to be run with a dedicated booster pump. Personally, I wouldn't want to go this route running one. You will reduce circulation elsewhere, and I'm not sure what to tell you about how much if will affect your pool pump, or how well it will perform being set up like this. Overall, I would say not too well, and certainly not ideally. I would consider a Robot instead.
    Essential Links:
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    Re: Polaris 360
    The 360 is the only one that does not require a boost pump, it runs off of the main pump. I have one running with my 2 HP pump on a dedicated return line and wall fitting. I don't think there is a specified pressure that is needed, but it does require an adequate flow rate to run effectively.
    J.R.
    20K IG gunnite pool
    2HP Hayward single speed pump
    Cartridge filter
