Results 1 to 7 of 7
Thread: Just received my TF-100 here are the results.
    Apr 2015
    aynor/south carolina
    7
    FC = 3
    CC = 0
    TC = 3
    TA = 150
    CYA = 40
    PH = 7.8
    Basic test kit showed TC at 2-4 which agrees with the other test.
    This is my first time using this kit. Unfortunately I've already spent a small fortune at the pool store and used about half of the supplies. I decided to go with TFP so I could learn how to decide on what I really need and save some money at the same time.
    My results look to be pretty good. I was surprised anyway. Where should I go from here?
    Thanks.
    AG 48" x 30', 25K gal, sand filter, 1.5 Hayward pump
    30,414
    Re: Just received my TF-100 here are the results.
    If your water looks as nice as those numbers look, about the only place to go is swimming.
    In your climate, you can consider running CYA a little higher....maybe 50 or so and then you'll have to adjust your FC up a little according to the FC/CYA chart. No big deal either way......you have really good numbers.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to the forum, good to have you aboard! Those look pretty good!
    Watch the pH and keep it there or little below.
    I would target 5 FC with a Cya 40, just to stay on the safe side.
    Essential Links:
    Apr 2015
    7
    Thanks! Good to hear I actually did something right. I lurked around on here for the past week trying to learn something. I took your advise, went swimming with my boy. It was sunny 80 degrees, water was a little cold, but we had fun.
    Quote Originally Posted by Patrick_B View Post
    Thanks i'll work on that.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Hi Pooljet,
    it isnt often that new folks have good numbers like you do.
    Did you just get lucky or do you know the FC/CYA chart?
    And the recommended levels?
    And how to use Pool Math?
    Divin Dave,
    Apr 2015
    7
    Quote Originally Posted by Divin Dave View Post
    Hi Pooljet,
    Didn't know much of anything. Bought our home late last year, pool is 10 yrs old, decided to work on the pool early which looked like a pond. Never had a pool before. Studied pool math as soon as I joined. The pool store helped some, confused me more than anything. I made small adjustments each time, then when everything tested good using test strips I added stabilizer. Shortly after I ordered the TF-100, I did the first test earlier today and came back with those numbers. We could say I got lucky. Hopefully it stays that way. I do plan to stay on top of it.
    By-the-way, the TF-100 is the best $68 I've ever spent. Looks intimidating at first, but once you get started, it's a breeze.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    That's really great to hear pooljet!
    Essential Links:
