Thread: fresh off SLAM test results/input
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    passed my OCLT last night, so wanted to do a full run of numbers for input. waiting for FC to drop
    FC: 26.5
    CC: 0.0
    PH: didnt take it due to high FC
    CH: 700
    TA: 120
    CYA: 70
    Salt: 3100ppm
    assuming i get my ph to 7.5, pool math says my CSI is 0.26 which is below the 0.60 number\
    i think overall pretty good, need to get my CYA up slightly. CH is a bit high, but i dont think its an issue since the CSI is below 0.6, agree?
    pool info below in signature
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    30,414
    Re: fresh off SLAM test results/input
    I think I would probably leave CYA alone. It will likely drop to 60 over the next month or so and then I would bring it to 80......no harm either way, tho.
    I'm sure you know your CH is a little high. When your FC comes down and you start to test pH, I would keep it (pH) in the lower 7'6 if it will stay there for you. Allowing (or doing on purpose) your TA to drop down may assist that lower pH. The whole idea in this paragraph is to keep a slightly lower TA and pH to offset your higher CH........that'll prevent any scaling.
    Nice job on managing your pool water.....you're off and running!!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Way to go Dan, good work man!!
    Essential Links:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Pictures or it didn't happen.
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    well the pool was never in bad shape, just slightly cloudy, no green. just couldn't get my SWCG to keep up and get FC in correct levels so i slammed it. it is quite a bit clearer though, even the wife says the pool has never been this clear. we've only been in the house a few months.
    Dan
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by DaninFLA View Post
    That's the TFP way man...crystal clear.
    Congratulations..
    Essential Links:
