Results 1 to 10 of 10
Thread: Just dump em all in at the same time
    LL Pool J's Avatar
    Sep 2014
    Australia
    4
    who cares about high cya. my target level is 100 because of the hardcore queensland sun. it's never hurt me brah i wouldnt worry about it
    also it will come down over time sooner than you think
    LL Pool J's Avatar
    Sep 2014
    Australia
    4
    chlorinator pays for itself within a few months; after that you're saving heaps of money
    there's no practical difference with the order you dump chemicals into your pool. just dump em all in at the same time if you like.
    6.8 ph is fine; your ph drifts upwards naturally anyway which is why you gotta keep chucking acid into your pool. i'd just dump in some bicarb soda which will raise your TA and ph, or just leave it raise itself naturally. only time you really have to increase your ph is if the kids swim in the pool and come out an hour later complaining about their eyes burning
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: High CYA
    Quote Originally Posted by LL Pool J View Post
    We do not suggest running this high. For the vast majority of pools by far, Cya 100 is too high. If you get an Algae bloom at 100 Cya its really a problem to overcome. Do what works best in your pool, but that level is not advisable.
    Essential Links:
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: SLAM & pH Question
    This is very poor advice, and taken literally by someone it could mean mixing them together might be safe. The results of doing that could be very bad.
    We have suggestions in Pool School about the proper way to add chemicals of all types. Please refrain from making such statements.
    Once again.....This is very poor advice.
    Also, pH 6.8 is not fine. If you hit it there as an overdose of acid that's one thing, but just as a statement it is not to keep it there. Again, there a specific reasons we give on the guidelines of chemical balance. Adding chemicals should always be done in a careful and calculated manner.
    Essential Links:
    Re: Just dump em all in at the same time
    Sensitivity to low PH varies, but just about everyone will be complaining about burning eyes when the PH is as low as 6.8.
    The real problem with a PH reading of 6.8 is that the most common PH tests will report anything lower than 6.8 as 6.8, so there is no telling how low the PH really is. Really low PH can seriously damage the pool in various ways. It is best not to take that risk.
    It isn't all that common, but adding pool chemicals in the wrong order and cause calcium clouding, which can't be filtered out and often won't go away until you adjust the chemistry correctly.
    I'm not really sure what kind of "chlorinator" you are talking about when you say "chlorinator pays for itself within a few months; after that you're saving heaps of money". Assuming you means salt water chlorine generators (SWG), they tend to break even with other forms of chlorine over the lifetime of the unit. With a SWG you spend the money up front, rather than slowly over time. The final cost tradeoffs can come out either in favor or against depending on what prices are in your area.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    The statements you've made in the two posts in all cases don't apply to my experience with my pool and especially the idea of dumping everything in at once. That is just a really bad idea for anyone no matter what pool or what conditions. Most of the chemicals can be harmful to the pool and or hazardous to the user if not handled properly and it's smarter to treat them with respect and adjust one parameter of the pools chemistry at a time so you're not taking chances.
    Solar Blanket, Well Water, Borax Added. 68
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    obvious the poster was just screwing with you guys...surprised people really gave real feedback.
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    You have to accept it at face value as there are people out there that just don't know any better.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    LL Pool J: You really need to check out Pool School
    Never gonna give you up, never gonna let you down...
    Isolated Spa - 345 Gallons
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,095
    It's clear that this post serves no good on TFP to remain open. Rather than allowing it to continue to be "bumped" up, it will now become closed. LL Pool J, if you wish for this to be re-opened please PM me and I'll happily allow you to continue this debate.
    Lee
