Results 1 to 11 of 11
Thread: Temp of return jet water low - is heat pump not working?
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    The answer to this question may be that everything is fine, and I just don't understand the detailed workings of how a heat pump heats, but is about a 5 degree difference in pool water vs return jet water temp typical, or could something be wrong with my heat pump? I just fired it up today; first time this season to be sure all is well. Water temp is about 55 or so. Water temp out of the returns is about 60. I recall last summer, feeling nice warm water coming out of the jets, but granted the pool was a lot warmer...does it only pump out water about 5 degrees warmer than the pool? Air temp right now is 72.
    I see no error codes, and it looks like it's working just fine...so really not sure.
    Thanks.
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    Aug 2013
    Maryland
    93
    Re: Temp of return jet water low - is heat pump not working?
    I believe in general that's how heat pumps work. They gradually heat air/water.
    I haven't had a pool heat pump, but a house heat pump only produces slightly warmer air.
    In a single pass through the heat pump the water only gains a couple of degrees. You keep doing that and the temperature will go up quite a bit, but it takes a while.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    Thanks guys. I do think it's ok now, just wasn't sure. So you put in 55 degree water, you get 60 degree. You put in 60, you get 65, 70 in, 75 out. That seems to be the deal then right?
    One thing though is man you can you feel cool air coming off the fan on the HP...wow.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    To me that sounds like you may not have enough water flow through the heatpump, as that may be TOO MUCH increase on a single pass for most efficient operation, check your owners manual though, it should tell you this stuff. The idea with any heat transfer is to heat as much water as little as possible so you don't waste energy making water hot, just to let it cool down. In other words it is generally better to heat 100 gallons of water 1 degree per pass than 1 gallon of water 100 degrees.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    The whole setup is 2" pipe, as called for by the heat pump, with a properly sized pump given distance, head loss, etc. I could be off a bit on the temp swing, it could have been 3, maybe 4. It was hard to hold the thermometer steady enough to get a solid reading. Interesting question though, and I'll look it up. One thing I can say is that I'm amazed at how cheap it is to run the HP.
    Jul 2007
    Suwanee, GA
    528
    5 degrees is quite good. I saw only a 2-3 when I had a heat pump. I can't say I ever tried to heat 55 degree water though.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    LOL. I hear ya crabboy. It was more to test it out and make sure all was well. My wife reports water temp is up to 66 right now...
    My heat pump indicates the flow can be as low as 30gpm. Is there any data on what the most efficient flow rate should be for a heat pump pro?
    2008 23K IG Liner, Pentair intellipump vf, 48DE filter, Heatpump, SWC, aquabot turbo T, K2006 Testkit
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Quote Originally Posted by jhirsch1 View Post
    Typically heat exchangers will be more efficient the higher the flow rate. It's easier to heat more water a little than less water a lot.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Searched the Hayward website. According to them "Hayward heat pumps have a flow rate range of 30 to 70 GPM, with an optimum flow rate of 45 GPM." Good to know.
