Results 1 to 10 of 10
Thread: Why would my "running pressure" jump up 5 PSI ?
    May 2009
    Youngsville NC
    395
    Ever since I installed the current pump, my usual steady state pressure on my filter had been 16.5 - 17 PSI (going up as the filter gets dirty- I flush it at 25% higher than starting). I replaced last years Nature2 Express cartridge with this year's and all of a sudden now I showing 21 PSi instead of 17. I even put in a new guage - still showing 21 PSI. All plumbing is 1.5 inch, and yes, I know my pump seems a little large - it replaced a 1.5 HP Superpump when it rotted out..
    Any ideas where to start ?
    I can replace the Superflo with a 30+ year old Hayward 3/4 HP Powerflo II that came with the house as a tub pump. I've used the Powerflo inbetween the Superpump going out and the Superflo going in, so I know it can handle the job.
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
    30,432
    Re: Why would my "running pressure" jump up 5 PSI ?
    You think there's a connection between replacing cartridges and the psi increase?
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    605
    The question is why are you using the Nature 2 Express? Do you know that is adds copper and silver to your water? This can cause many undesirable issues with your water as the amount of minerals increase year after year. Search this forum for Nature 2 and see what I mean.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    May 2009
    Youngsville NC
    395
    Yes I'm quite well aware of the Nature2 and how it works. My metals are quite low, and I run low chlorine (due to many trees - as of right now my pool temp is still only 59 F - and the pool has been open for a month). I don't even need to use any more stabilizer than comes in the standard 3 inch tablets. I really want to put in a heatpump. - Like I said my problem is the jump in running filter pressure from 17 to 21. and I had considered the idea it was the new cartridge.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    If you still have the old cartridge try swapping them again to see if it goes back down.
    Solar Blanket, Well Water, Borax Added. 76
    Oct 2012
    605
    2nd what kiss4aFrog said. Any chance it is bad cartridge?
    May 2009
    Youngsville NC
    395
    I suppose it's possible. The old one is off at the trash.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Next time you might want to hang on to one just in case you need to pull the good one for any reason you can always toss an old one in to run the pump.
    Is there any chance something is stuck in the new one or it came with something protecting the grids that was supposed to be removed before install ??
    I don't have one so I'm just shooting in the dark.
    May 2009
    Youngsville NC
    395
    I thought of that and took it off to check - didn't see anything I could access. I've been using Nature2 since 2000 and like how I can run low chlorine and not get algae.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Eventually, you will along with metal staining. Your choice, just sharing the info.
    Essential Links:
