Thread: How "clean" should my cartridge filters look?
    Aug 2011
    Northville, Mi
    312
    I've got 2 sets and had the pool for 3 seasons (bought the 2nd set after a year with the 1st set).
    Even after I've cleaned them and watched what looks like a pound or two of gray junk get washed out of them, they stay gray. I just finished an overnight soak in TSP (1 cup/5 gallons) and rinsed them out and they're *still* gray.
    Yet, they seemed to be doing fine last year and my pool was crystal clear all season.
    Am I still not cleaning them enough? How can I tell if they need replacing?
    Is it a good test to fire up the pump at full blast without them, get the pressure, then fire up the pump with them and see what the increase is?
    BTW - sorry I'm a constant flurry of questions lately...did I mention I'm opening my pool myself for the first time?
    15,400 gal, 16x32 vinyl rectangle (sport dig), Intelliflo VS, 240 sqft cartridge filter, Intellichlor IC40, Mastertemp 250, Dolphin supreme M4 cleaning, Pentair EasyTouch4, Tested regularly and accurately with supplies from tftestkits
    Re: How "clean" should my cartridge filters look?
    Cartridges often turn gray or brown after a few years. It doesn't really mean anything.
    The real test is watching what the clean cartridge filter pressure does. As long as that goes back to somewhere around what they were when new you are fine.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Yep, mine are discolored too. Next time you buy a new set try some Pleatcos. They seem to clog less, clean easier, last longer, flow more and keep the pool just as clean.
    Here is a link that goes more in depth on cleaning.
    http://www.troublefreepool.com/threa...rtridge-filter
    Aug 2011
    Northville, Mi
    312
    The extra set I got are pleatco. Pressure was the same with and without the filters at max speed on the pump so I figure the filters are fine.
    Thanks guys!
