Results 1 to 9 of 9
Thread: Um...what the heck is this plug??
    Aug 2011
    Northville, Mi
    312
    Had a company close for me last winter and opened up my pump and found this plug. Have *no* idea what the heck it is or where it goes! The threads are the same size as the return openings, but this was in the pump basket in the pump.
    Help!
    15,400 gal, 16x32 vinyl rectangle (sport dig), Intelliflo VS, 240 sqft cartridge filter, Intellichlor IC40, Mastertemp 250, Dolphin supreme M4 cleaning, Pentair EasyTouch4, Tested regularly and accurately with supplies from tftestkits
    Re: Um...what the heck is this plug??
    That looks like a filter drain plug to me, though I can't be certain.
    If you can't figure out where it goes, water will spray out from the correct spot as soon as you turn on the pump. So one way or another you will be able to figure it out eventually.
    Aug 2011
    Northville, Mi
    312
    And that *is* the common sense way of looking at it!!!
    Thanks Jason. Makes perfect sense now!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    That looks exactly like the drain plug on my Pentair cartridge filter. I like Jason's approach! Much more exciting!
    It's a Pentair filter drain plug. Sometimes the drain hole is difficult to get to and not obvious.
    Support the site
    DFW, TX
    24,509
    That's right it is hidden under the plumbing down at the bottom. A bit of a pain to get to and get the threads started.
    Aug 2011
    Northville, Mi
    312
    Yep. You guys were right about all of it! Pentair filter drain plug, not obvious, and a pain to get the threads started!! But it's in and sealed tight now.
    Incidentally, Jason's approach worked perfectly with a different plug in the system that I didn't even know was out! It was indeed quite exciting, although would have been moreso if I had been standing in front of that plug when the water came out in a hose-like stream! Ah, the adventure of owning a pool!
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    Quote Originally Posted by doncaruana View Post
    We need photos.....
    Support the site
    Aug 2011
    Northville, Mi
    312
    Ah, but if only I had a camera rolling when that stream came out and almost nailed my neighbor who ha come over to talk to me!!
