Thread: dummy plug in skimmer
    Mar 2009
    Charlotte, NC
    539
    I have 2 openings in my only skimmer. One is open & working fine.
    The other opening is really a dummy, it's solid. When I winterize I do close it with a winter screw-plug (just to have less clean up tasks at the spring opening & just as well because it could fill & freeze I suppose).
    Is that necessary to do in the winter? , and
    Is it best to leave it plugged in summer or not or makes no difference?
    Thanks
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    Re: dummy plug in skimmer
    It doesn't really matter if you plug the second hole in the bottom of the skimmer or not. The only time it would matter is if it was leaking, but I wouldn't expect that to happen.
