Thread: Water Coming out of Spa Air Intakes
    wjr75's Avatar
    Jun 2013
    IL
    836
    Just opened our pool and the spa jets are not fully turning on as full strength as usual. There is also water coming out of the two air intakes on top of the spa. Any ideas what is causing this and a fix? Thanks.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    mas985's Avatar
    Pleasanton, CA
    11,743
    Re: Water Coming out of Spa Air Intakes
    Could be something clogging the spa jets. Remove the inner nozzles and try to flush them out.
    Mark
