Thread: Heater leaking
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Heater leaking
    Hey guys,
    So my heater is leaking from the "hose port"... Im calling it that because I cant think of anything else to call it and it looks like a hose would connect to it
    Its a pretty fast leak. No matter how much I tighten the bolt to the right of it, I can not stop or slow down the leak. The heater seems to work fine. Is there a way to cap this off and if so, would it cause any problems if I do? Thanks a million!
    Pic below:
    https://www.dropbox.com/s/ud9bwwny42...20am.jpeg?dl=0
    18x38 Inground Liner (25k gal) Paver surround, multi-speed pump, DE Filter, Raised spill over spa, TF-100
    30,415
    Re: Heater leaking
    That's called a hose "bib". Why, I have no idea.....sounds stupids.
    For less than $10 at any hardware store, you should be able to unscrew it right where it goes into the heater protrusion and replace it with a new one (the new one will even have a handle). Put a few wraps of teflon tape on it or some pipe sealant and enjoy your swim season.
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Re: Heater leaking
    Awesome! OTW there now. Thanks a lot!!!
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Heater leaking
    You could also just pick up the rubber faucet washer part for cheap at a hardware or big box store.
    Solar Blanket, Well Water, Borax Added. 68
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Re: Heater leaking
    Thanks guys. I actually grabbed a hose cap for about $1.50 and capped it off.
    Ill switch out the entire thing soon. Really appreciate the help!!
    ps0303's Avatar
    Jul 2011
    FL
    3,691
    Re: Heater leaking
    Actually that shouldn't be on your heater at all. I'm sure that it's used for draining the unit for winter but a hose bib isn't really the best thing to be used. A proper plug is a better choice.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
