Results 1 to 15 of 15
Thread: How much shock should you add for the first time.
    May 2015
    Long Valley
    6
    I am brand new to this site and have read as much as I can. We just opened the pool and have run the filter overnight. The cc is at 0 which I know is normal. I believe the next step is to add shock. How do you know how much to add and how long should we wait before testing the other chemicals?
    Thank you in advance.
    18 k, vinyl, SWG, Polaris
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: How much shock should you add for the first time.
    Welcome to the forum!
    When you say shock, most of us here think of the process of "shocking" a pool. Most here use liquid chlorine, sodium hypochlorite, otherwise known as bleach.
    Can you post a full set of test results? We can go from there for any advice needed.
    May 2015
    Long Valley
    6
    FC-0 PH-6.8 and CH100
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,648
    With a SWG, do you already have your salt at the correct level and also cya at 70 to 80? If so, add enough plain old beach to bring FC to 4 or 5 so your SWG can take over without much strain. A gallon and a half should do you. That PH needs to crawl into the 7.4ish range as well. You list no reading for your TA level. Welcome to the forum and enjoy pool school.
    May 2015
    Long Valley
    6
    Thank you so much for your help. I don't think my husband gave me the TA level, we thought first step was the shock/bleach. Wish I was a chemistry major!!!!
    30,431
    Welcome to the forum.
    Have you found Poolmath on our site that will help you figure your dosages?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Welcome to TFP!
    TFPC does require a little reading up front to get there. But, once you do you can look forward to many years of sparkly pool swimming that is troublefree.
    Start here,
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Water Balance for SWCGs
    Please update your location and signature as shown here.
    May 2015
    Long Valley
    6
    We had to fill the pool with well water and the water is too cold for the SWG to give a reading. Any suggestions on what to,put in first?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    If you can give a fresh set of test numbers, we will be glad to answer. At least the primary ones...
    FC
    CC
    pH
    TA
    Essential Links:
    May 2015
    Long Valley
    6
    FC-3
    Ph6.8
    TA-80
    CC-need 5 more degrees to get a reading
    CYA-25
    CH-200-300
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    I'm guessing 2 gals of 8.25% bleach, but pool math would answer better
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    May 2015
    Long Valley
    6
    Thanks,I'll plug it in
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Quote Originally Posted by obschilling@gmail.com View Post
    FC-3
    Ph6.8
    TA-80
    CYA-25
    CH-200-300
    FC needs to be brought up. Also temp won't affect CC reading.
    Your CYA is low 30-80 if you are slamming about 30 is good and your PH needs to be 7.2-7.6 slamming 7.2 is good range is low.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Here is a link for recommended levels http://www.troublefreepool.com/conte...mmended-levels
    Lisa
    DFW, TX
    24,509
    Chlorine is always #1 and PH is #2. Everything else can be worked more slowly and managed as you go.
    The Chlorine CYA Chart tells you what the min FC level is for your CYA level. Never let the FC level fall below the min or algae will start to grow. Keep PH between 7.5 and 7.8. Everything else can be managed.
