Results 1 to 7 of 7
Thread: SALT... too high... too low...?
    melbajr's Avatar
    Aug 2013
    Florence, SC
    54
    Question SALT... too high... too low...?
    help, i opened my pool and after the slam everything was going well. then a few days ago my swg red light said that my salt level is low. I was surprised to see that so i tested my salt levels (aqua check strips) and my salt was around 3200 ppm which is a little lower than ideal so I added the recommended salt and today my swg red light is still on but when i tested again it showed 3790 ppm! what am i missing? yesterday's test results:
    FC=2
    cc=0
    pH=7.5
    ta=80
    ch=75
    cya=80
    Any thoughts as to what my next step should be? i checked my cell in the fall when closing the pool and it was clean as a whistle. should i check it again?
    Grecian 11,800 gal. IG vinyl, Pentair TA-60 sand filter, 1.5 hp Superflo, built in 2007, replaced vinyl & converted to Intellichlor IC-40 SWG in 2012 after we purchased home. TF-100 Testkit, SWG manufacturer recommends salt levels 2600-4500, ideal being 3400-3500. Polaris 180 vac.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,591
    Re: SALT... too high... too low...?
    Takes about 24 hours to get a good reading on a new salt addition being circulated well. How old is the cell?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Or longer if the pump isn't running or you don't brush to mix it in. And test strip accuracy is +/- 400 or 500. If the SWG is happy everyone is happy.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    From your results it looks like your below minimum on your FC for a CYA of 80. Should maintain a minimum of 4 per the chart http://www.troublefreepool.com/conte...art-slam-shock
    Wouldn't hurt to check the cell to make sure it's still clean.
    Solar Blanket, Well Water, Borax Added. 68
    melbajr's Avatar
    Aug 2013
    Florence, SC
    54
    Quote Originally Posted by woodyp View Post
    it had been at least 24 hours circulating after adding salt. the cell is 3 yrs old.
    thanks for your response and any help or advice you provide!
    melbajr's Avatar
    Aug 2013
    Florence, SC
    54
    Quote Originally Posted by pooldv View Post
    I've always believed that but my numbers have never been so far off before!
    pump is running and i brushed, too.
    i hit the SWG boost for 24 hr on 100% run and have it set at 60%. my pump is running 24/7 since opening because my digital display is not readable (gotta do something about that too)
    melbajr's Avatar
    Aug 2013
    Florence, SC
    54
    i agree about fc which is why i did the 24 hr boost on swg. in the past it usually did the trick.
    i am out of town, left yesterday and back tomorrow. i'll recheck my numbers when i get home and post again. i'll check the cell too! thanks for your help!
