Thread: Dull Water and Hard Water Buildup
    Mar 2012
    Sacramento, CA
    6
    Chlorine and ph are good. Water seems dull. I'm very sensitive to the clarity of the water and I know when something is off. We added a flocculant since we had a lot of debris from some landscaping work and it is better but not where it should be. Also, we have lots of had water build up. Any suggestions?
    Approx. 20,000 gallon In Ground pool/spa combo, Pebbletec Finish, Intelliflo 3HP Variable Speed Pump, Pentair Clean & Clear 420 Cartridge Filter., Intellitouch system, Hayward heater (and that's about all I know for now)
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Dull Water and Hard Water Buildup
    Stop using floculant would be my first suggestion.
    You say FC & pH are good, but wat is good? What is your CYA.
    Dull,water is usually the first hint that algae is rearing its ugly head.
    Support the site
    30,421
    Flocculant often does more harm than good. Your filter and pump should be perfectly capable of keeping your pool crystal clear.
    That said, if you FC is too low for the CYA level, you can easily have algae that will make your water dull. Posting up a complete set of current test results would probably be very helpful.
