Thread: Best way to raise FC
    Nov 2014
    Palm Desert, CA
    99
    The last few weeks has seen my FC drop. Last week was 4 and today is 3 (CYA is 50). My salt is reading 2900 with a 50% output. Should I raise the output to 70% and check again in a few days or go ahead and shock the pool now?. I have some Fresh and Clear Oxidizing Shock and some trichlor tablets. Also, how long after adding acid can I try to raise the chlorine? Thank you!
    17,000 gallon inground pool; Plaster redone January 2015; Pentair Cartridge Filter; SWG; Age of pool unknown (house built in 1973); Taylor K-2006 Test Kit.; Doheny Discovery robot cleaner.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Best way to raise FC
    If the water is otherwise clear, I'd just crank up the SWG. As temperatures rise and there's more hours of daylight, chlorine demand goes up. And if anyone's using the pool, it will go up more. So raise the SWG percentage or increase the filter time.
    With a SWG it is recommended to keep CYA around 70 to 80. That will allow you to run the SWG at a lower percentage setting.
    Jan 2012
    'burbs of Augusta, Georgia
    7,252
    How does your water look? What are you using to test with?
    If it were my pool, I'd toss in about 2 ppm of regular household bleach (using PoolMath calculator to determine how much that is in the pool) and recheck in a day to see how much you're losing. Does your SWG require more salt than its got to work with? Mine needs more than the 2900 you've got.
    If you're looking to raise your CYA you can use those pucks, but cautiously. Once you add CYA, if you get too much, you're stuck with it until you drain and exchange some water for fresh water. Each puck contains some. Again, down at the bottom of PoolMath it can tell you the effects of adding x amount of chemical.
    At least 30 min between acid and other chems
