Results 1 to 7 of 7
Thread: Compool cp3600 clock stuck
    Jun 2013
    Dallas, TX
    105
    We had a power outage last week. When it came back on my control panel was reading the wrong time. I reset it, but the time never moves, always stays where I set it.
    As a result the timed settings never kick on. I've reset the control panel and the main board but neither seemed to fix.
    Everything else seems to work fine. Is there something I need to do to get the clock to start running?
    35k gal, sand, IG, diamond brite, Hayward Goldline T-CELL-15 Turbo SWG, Aquarite, Compool Lx3600
    Jun 2013
    Dallas, TX
    105
    Re: Compool cp3600 time stuck
    Also may be worth noting the ":" on the clock is flashing as normal.
    Re: Compool cp3600 clock stuck
    I am not sure about the Compel units, but many of those clocks run off a separate small battery mounted on the circuit board. The clock is often powered by the battery so it will keep correct time even when the power is off. Often the clock stops running when that battery goes dead.
    Jun 2013
    Dallas, TX
    105
    Just replaced it and reset the clock again. Still not working
    Jun 2013
    Dallas, TX
    105
    Bump
    Jun 2013
    Dallas, TX
    105
    It now appears the time is being reset back to 12:00, at least once a day and still not running when set. Any ideas?
    Dec 2017
    Dallas/TX
    1
    Did you ever figure this out? I replaced the battery too and my pump has been running non-stop ever since,because the clock will not move. The clock on the keypad outside works just fine, but the one on the controller inside the house is stuck, with the ":" flashing as if it were working. Everything else seems to be working normally...
