Results 1 to 16 of 16
Thread: Rust Removal
    todd.scallions's Avatar
    Apr 2010
    Bartlett, TN
    57
    Rust Removal
    Does anyone know what chemical I could use to get this rust stain off my skimmer plate? Obviously I don't want to use a chemical that's going to screw with my water chemistry. Thanks! Would some ascorbic acid do the trick?
    https://www.dropbox.com/s/rpt37huczw...20PM.jpeg?dl=0
    1.) 27,000 gallons
    2.) Sand Filter
    3.) In-ground
    4.) Vinyl Liner
    5.) 1HP/63GPM
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Re: Rust Removal
    Naval jelly?
    Aug 2010
    Coastal NC
    12
    Re: Rust Removal
    You could also try white vinegar. I have used it to remove rust stains from concrete. Use a brush to scrub it with the vinegar.
    26,000, 16x36 vinyl IG, Sand Dollar Sand Filter, 1 HP pump, Installed June 2010, Jandy Aquapure Ei
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Rust Removal
    I would just mash up a bunch of Vitamin C tablets and make a paste and smear it on. I lifted some rust spots off the plastic patio table that way.
    Feb 2014
    Upstate, NY
    390
    Re: Rust Removal
    I would also remove that screw and replace it with a new one.
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    ernie01jt's Avatar
    Mar 2015
    Smithton IL
    178
    Re: Rust Removal
    What Donny said, and then buy a cover plate that goes over your existing plate
    18' x 38' 20,500 gallon vinyl IGP, 3.5 - 7' depth, Pentair FNS Plus DE filter,
    2hp Whisperflo high performance pump, 1.1hp boost-rite pump for the cleaner,
    250k BTU MasterTemp heater, LetroLegend pool cleaner, Hayward TurboCell GLX-CELL-15 chlorine generator
    Speedstir, K-1776, TF-100
    Apr 2010
    Bartlett, TN
    57
    Re: Rust Removal
    Hmm, where would one buy a cover plate for the skimmer plate? I never even knew they had something like that.
    1.) 27,000 gallons
    2.) Sand Filter
    3.) In-ground
    4.) Vinyl Liner
    5.) 1HP/63GPM
    Apr 2010
    Bartlett, TN
    57
    Re: Rust Removal
    Found one on the Amazons! Thanks everyone.
    1.) 27,000 gallons
    2.) Sand Filter
    3.) In-ground
    4.) Vinyl Liner
    5.) 1HP/63GPM
    ernie01jt's Avatar
    Mar 2015
    Smithton IL
    178
    Re: Rust Removal
    Glad you found them, 'cause I forgot where I saw them
    Apr 2010
    Bartlett, TN
    57
    Re: Rust Removal
    I ordered new screws and a face plate. Two questions: will removing these screws cause my liner to slip away from the skimmer and should I drain the water down below the skimmer to install the faceplate? Not sure if the faceplate forms a water tight seal around the skimmer plate or if it's more of a decorative thing.
    1.) 27,000 gallons
    2.) Sand Filter
    3.) In-ground
    4.) Vinyl Liner
    5.) 1HP/63GPM
    ernie01jt's Avatar
    Mar 2015
    Smithton IL
    178
    Re: Rust Removal
    Hi Todd,
    I missed your last post. I just went out and took my face plate off. There was a gasket between the face plate and the liner. There is also a gasket between the liner and skimmer. Hayward SP1084FGR Gray Snap on Face Plate Cover Replacement for Hayward SP1084 Skimmers on Amazon and elsewhere, not sure of your color, it snaps on over the face plate hiding screws.
    Ernie
    Apr 2010
    Bartlett, TN
    57
    Re: Rust Removal
    So they way mine looks is I have the skimmer plate with screws, then the liner, then the nasty exposed pool wall, then the skimmer. I just had the liner installed last year. I don't know why the installer didn't do something about that nasty rusty ****. I'll take a picture of it when I get home that shows the pool wall.
    1.) 27,000 gallons
    2.) Sand Filter
    3.) In-ground
    4.) Vinyl Liner
    5.) 1HP/63GPM
    Apr 2010
    Bartlett, TN
    57
    Re: Rust Removal
    Here are some pics.
    1.) 27,000 gallons
    2.) Sand Filter
    3.) In-ground
    4.) Vinyl Liner
    5.) 1HP/63GPM
    Apr 2010
    Bartlett, TN
    57
    Re: Rust Removal
    I read another forum tonight that said to drain the water below the skimmer and then use aquarium silicone on the rust.
    1.) 27,000 gallons
    2.) Sand Filter
    3.) In-ground
    4.) Vinyl Liner
    5.) 1HP/63GPM
    ernie01jt's Avatar
    Mar 2015
    Smithton IL
    178
    Re: Rust Removal
    Hi Todd,
    The brown you see behind your liner is a gasket, possibly two. Where mine had a gasket on either side of the liner it looks like yours has both behind your liner.
    Did your new plate come with a new gasket? On mine when I took it off the old gaskets tore, they aren't designed for re-use. I would use new ones.
    The installer didn't do a very good job at your skimmer, or at least I should say that the faceplate on mine hid both the cut edges of the liner and gasket.
    Ernie
    Apr 2010
    Bartlett, TN
    57
    Re: Rust Removal
    I agree 100% about the installer not doing a good job. There is something about the service industry in the Memphis area.... They all suck. Plumbers, HVAC, pool contractors, mechanics, etc. Every single one of them that I have dealt with over the years have always been the type to cut corners. Whatever gets them finished so they can move on to the next job. I don't know what it's like in other cities but Memphis, TN is rampant with that type. The new one should arrive today. It's just the snap on faceplate to hide the screws.
    1.) 27,000 gallons
    2.) Sand Filter
    3.) In-ground
    4.) Vinyl Liner
    5.) 1HP/63GPM
