Thread: Pool Pump Leaking
    Pool Pump Leaking
    Help everyone,
    I have a pool pump assembly that is leaking. I can hear the hissing sound when putting water on it. The pump is not charging. Any suggestions?
    Re: Pool Pump Leaking
    If may be a bad seal, in which case the seal can be replaced. It might also be a cracked part of the pump body, which can also be replaced, though slightly more expensively. You will probably need to disassemble the pump to be sure.
    Any special instructions on disassembling?
