Thread: First time Opening with TFP - Advice on my plan
    Apr 2015
    Mississauga, ON, Canada
    31
    Took the cover off the pool today!
    Cloudy, but not green, so pretty happy about that.
    After some vacuuming and having the filter run for about 4 hours I did my tests. (waiting on the FAS DPD add-on kit, so just used the Taylor 2005 so far)
    FC 3
    TC 2
    CC 1
    PH 7
    CYA didn't register (so < 30)
    CH 150
    TA 60
    I took the water to the pool store to confirm - first time using the Taylor kit.
    Their values were
    FC 2.67
    TC 2.98
    CC .31
    PH 7.3
    TA 69
    CYA 5
    CH 189
    My plan is to first get CYA up to 40 - hung a sock in front of the return
    - as this is a "expensive" test to run, since it uses so much of the reagent - when would be a recommend time to test again, now that I've got my sock in there?
    What's next?
    Pool store has my CC < 0.5, so I dont think I need to SLAM, but am open to advice on this as it's my first time with this method.
    Pictures!
    after opening, and vacuuming the shallow end.
    Attachment 35888
    after vacuuming whole thing.
    Attachment 35889
    Thanks everyone!
    13K gal 18'x36', IG vinyl, Hayward MaxFlo SP23520VSP Pump, Hayward pro series sand filter, Hayward Aquarite SWG, Raypack R266 NG Heater, Dolphin Premium (S300i) Robot, Custom controller (in progress)
    Re: First time Opening with TFP - Advice on my plan
    Give the CYA a week to dissolve before testing again.
    I recommend adding about 3 ppm of chlorine this evening. Then tomorrow switch to targeting an FC level appropriate for your CYA target level.
    I would bump the PH up to roughly 7.5.
    Otherwise you should be alright for a while.
