Results 1 to 19 of 19
Thread: I guess this is a start up question
    ground_trooper's Avatar
    Apr 2015
    Glendale AZ
    12
    I had a tree roots vs pool pipes situation. We had to cut out some roots, and ended up rerouting some pipes. In the process we had to do 2 partial drains to get water below wall returns because we didn't know what pipes were what. So basically I am starting over and want to start up right.
    We had our first 100 day yesterday so my water temp is already around 78.
    My test today as is follows.
    FC - .5
    PH - 8
    TA - 130
    CH - 170
    CYA - I really can't get a read because the water is not cloudy once the tube is to the top. (Unlike in the past! LOL)
    For kicks I knew I was going to need some stabilizer to start up so I took a sample to Leslie's as I knew they at least test with a Taylor kit.
    We pretty much match although they say my CYA is 25
    Where do I need to start?
    They suggested 1/4 - 1/2 Gal of CYA
    and a bag of SHOCK and of course PhosFree. (I am no fool on PhosFree. I know that deal)
    I wanna do this right so I am asking for your help. I learned of BBB last year after a "LOCK" (I was running way to many tabs) I vowed to never go down that road again.
    Thanks in advance for your help!
    11,790 Gallons - IG - Pebble - Sand Filter - Triton II - WhisperFlo 1 Speed - Paramount PCC2000 Infloor Cleaning & Waterfall - was Built in 2000. Taylor K2006C - Tired of the FOOL Store run around. Trying BBB/TFP
    Re: I guess this is a start up question
    Welcome to TFP!
    Start by lowering the PH to 7.2.
    Raise CYA 30 ppm. Use the granular stuff, not the over priced liquid.
    If the water looks good, add about 5 ppm of chlorine this evening, and then tomorrow start targeting the FC level appropriate for a CYA of 50 (assuming you add CYA today).
    Longer term, you need to raise CH to around 300 to 350. But wait until most everything else is stable before doing that.
    Apr 2015
    Glendale AZ
    12
    Quote Originally Posted by JasonLion View Post
    Welcome to TFP!
    Ha Ha I already bought the liquid when I was there. Is the only difference the price?
    At this point it is not worth it for me to drive back and hassle them with a return unless the outcome will be better with granular.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Welcome to the forum ground_trooper
    The liquid is just more expensive. It's nice in that you pour it in and it's "there". The liquid adds it right then and if you wanted you could retest after 30 minutes of pump time to mix. With the granular like HTH at Walmart, HomeDepot ... you add it in a sock and once it dissolves from the sock it still takes up to a week to fully dissolve into the water but almost everyone uses the granular.
    Solar Blanket, Well Water, Borax Added. 68
    Apr 2015
    Glendale AZ
    12
    Well I guess this time I will flush my $$ down the drain. I don't want the hassle. Off to Lowes to get some MA as I am almost out!
    Thanks for you help! Next time I will go powder!
    Apr 2015
    Glendale AZ
    12
    OK I had a little incident tonight. I realized that I should probably backwash my pool since it has been a while since I had done it. Before putting all these new chemicals in and then washing them out.
    Anyway, my backwash hose twisted into a kink and it exploded about 3 feet from the filter outlet. I shut it off immediately. But instead of stopping and thinking about my options I undid the hose, switched the valve back and turned on the pump to run the filter as it was scheduled to turn on in 5 minutes anyway.
    So there was still some gunk/sand in the line because I didn't let it run long enough to run it clean. So I pumped whatever was left into my what used to be a crystal clear pool.
    So tonight I have a very cloudy pool because of the sand.
    Did I just wreck my crystal clear pool? or will the sand work it's way back through the system and back into the sand filter?
    Thanks for your help again.
    I have been working on the CYA and PH from my initial posts.
    We just had a couple of days of rain so it has hampered some of my efforts.
    ---Edit---
    So after I thought things out. After I stewed for about a half hour I went and cut my hose at the burst point and hooked it back up and did a successful back wash.
    Can I expect this to clear up over time or what.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    Yes, it will clear up on its own. You can run the pump longer to speed it up. Are you adding chlorine daily? Seems like you are living on the edge letting FC drop to .5. With cya at 25ish, take a look at Chlorine CYA Chart and see that the target FC is 4 and minimum is 2. Don't let FC drop below 2 or algae will grow.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Algae comes with a quickness if you let your FC drop that low.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Depending on what all was blow back into the pool you might need to vacuum to get it all but it's just a matter of running the pump long enough to recapture what's in there causing it to be a bit cloudy.
    After you backwash do you use the "RINSE" before going back to filter ??
    Apr 2015
    Glendale AZ
    12
    Quote Originally Posted by pooldv View Post
    Ya I am living on the edge. I do have some yellow slime on my walls.
    I added 2 gallons of bleach and the bag of shock I had bought.
    My PH is still in the 8+ range so I will work on it and it looks like my CYA is still around 25. So I need to go a little higher there.
    I have and old school filter. All I have is an open/close for back wash. I don't have one of these new ones with different settings. So it is all or nothing.
    DFW, TX
    24,468
    Make sure your FC is below 10 when testing PH or the PH test result will be artificially high.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by ground_trooper View Post
    Sorry to say, if you have yellow slime on your walls you are over the edge. Get the pH in line and SLAM your pool.
    Read the directions on SLAMing your pool in the How To section of Pool School and follow that procedure completely to the end.
    CC is 0.5 or lower;
    You pass an OCLT (ie overnight FC loss test shows a loss of 1.0 ppm or less);
    And the water is clear.
    When all three are true, you are done SLAMing and can allow the FC to drift down to normal levels.
    Support the site
    Jan 2012
    'burbs of Augusta, Georgia
    7,301
    Don't forget that that bag of "shock" you added also contains CYA.
    Apr 2015
    Glendale AZ
    12
    Quote Originally Posted by YippeeSkippy View Post
    Yes Yippee, I figured that was the case. With the CYA.
    Considering I was still on the low side I figured I might as well use it.
    Should I brush the walls or just let the SLAM do it's thing?
    May 2014
    Franklin, NC
    9,184
    Part of the SLAM is brushing the walls. Did you read it?
    Support the site
    Jan 2012
    7,301
    Oh yeah, brushing is always a good idea during a SLAM. Brushing disrupts any algae and biofilm on the walls and floor and lets the Chlorine get at it better.
    Apr 2015
    Glendale AZ
    12
    OK I think I am really close. I had an overnight loss of 3 points and I have no CC. But I couldn't get up before the sun (2 hours after sunrise) as I have been a little ill. I am going to continue shock levels through today and see how my overnight loss looks tomorrow.
    FC 8
    PH 7.6
    CYA 30
    I have added a whole bottle of liquid Stabilzer and 1 bag of shock and my CYA is at about 30.
    In my very sunny climate what is my best low end CYA Level? 40?
    Thanks again!!
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Think of brushing your pool like brushing your teeth. It's a really good habit to get into as it helps prevent problems since you're helping circulation in places that might be a bit stagnant. Helps mix things up so the filter can get them too.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I live in SE AZ and I have a SWG. I keep my CYA about 75. Since you don't have a SWG and your sun is more intense than down here I would shoot for CYA of 50
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
