Thread: Robots
    Robots
    Hi,
    FAQ for robots doesn't speak to these questions:
    1. You put the robot in the pool when use needed? What do you do when you are out of town?
    2. Waterproof cord is long enough for all pools?
    Please forgive me if I need to read more about this before asking such basic of questions.
    But the Legend is crapping out and need a new pressure side cleaner (my luck I do, and then my 9 yr old booster pump will croak) and maybe it is time to see about a Mr. Roboto...
    Bob
    Thanks As Always!
    Bob
    23,000 gal in-ground, Aquarite salt sys, Intellitouch i7 +3, Hayward cartridge filter (4) C-5025, Polaris 280 Pool Cleaner, 3/4 HP booster pump, Hydrazzo plaster.
    Re: Robots
    1) As needed. No robot while away.
    2) Just about, they are quite long.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Robots
    The cords are typically 50-60 ft long.
    Ive left my robot in the pool for a week or so, but generally I take it out sometime during the day that I used it.
    Unless you get a fancy one that has a timer, then it wont clean while you're out of town anyway, so no use in leaving it in the water. And even if you do get a fancy one, the timer has to be re-set each week. It doesnt endlessly repeat. (at least thats the case with Dolphins,.. not sure about other makes).
    Divin Dave,
