Thread: AGP Install - Bottom higher than wall track?
    May 2008
    IL
    26
    I am in the process of switching out from a 48 Inch to 54 inch pool. It actually was a mistake that I bought the 54 inch walls, but it was a closeout last year so I'm stuck with it. The tricky part with this pool is that sits level with a 48 inch deck, so I need to dig down to make the 54inch walls level with the deck. I've already torn down the old pool and have dug a 6 inch trench with pavers set 2 inches below that. I dug out about 2-3 inches from the middle section of the pool, but to be honest it is killing me.
    I'm wondering if it will hurt the integrity of the pool if I set the post so they're level with my deck, and then only dug about 3 inches from the middle section would leave me with 3 inches of dirt, an inch of sand, a gorilla pad and side cove which would bring the bottom of the pool up to about 50 inches. So basically it would look something like this:
    |50 inches of Water |
    |inch of sand and gorilla pad |
    |3 inches of dirt |
    |----------------------------------| --- Posts on blocks
    21' Doughboy AGP
    1HP Pump
    Hayward Sand Filter
    Hawyard H-150 Heater
    Intex SWG
    Re: AGP Install - Bottom higher than wall track?
    As long as you have an overlap liner (folds over the top rail) that is fine. A j-hook liner would leave the j-hooks too high, with nothing to hook them to, if you do that.
    May 2008
    IL
    26
    Thanks for the quick reply!! Yes, it is an overlap liner.
    My back thanks you.
    21' Doughboy AGP
    1HP Pump
    Hayward Sand Filter
    Intex SWG
