Results 1 to 7 of 7
Thread: Does anyone know the sand gap dimension on a Hayward sand filter model S244T?
    Apr 2014
    louisville,ky
    37
    Hello,
    I am going to clean my sand tomorrow while I add some unions in my supply lines. It was hard piped in originally. Anyway, I can't find anywhere what dimension I should use from the top of my sand to the filter body opening. The only info I can find is it holds 300#'s of sand. Does anyone know that dimension so I know if I need to add sand?
    Thx
    24,200 gal IG vinyl liner. Sand filter 1 1/2 hp Haywood pump. T2 turbo pool cleaner
    38,449
    Re: Does anyone know the sand gap dimension on a Hayward sand filter model S244T?
    I think it should be over 50% full and not be above where the tank starts to get smaller. Not sure of a dimension though.
    Mar 2015
    Indiana
    79
    I just installed one of those two weeks ago but didn't think to measure the distance. I remember thinking I could have gotten at least another 50# bag in there. I'm guessing between 8-10 inches from the top. Jblizzle's info sounds like a safe bet.
    17x41 Sun Fiberglass Pool 21,500 gallons. Jandy 1hp pump, Hayward Top Mount Sand Filter, Coverstar Auto Cover.
    Apr 2014
    louisville,ky
    37
    Ok got my sand clean and union installed. Cover off,debris removed and automatic cleaner doing it's magic.
    My test #'s FC:1 CC:1 CH:300 TA:50 PH:7.2
    CYA...well I filled the tube all the way and can still see the dot. So I'll call it 10.
    My question do I bring up CYA and then add chlorine to bring that up. Does it matter?
    Thx
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,049
    Quote Originally Posted by egadds View Post
    Thx
    CYA takes a while to dissolve. Don't wait on the chlorine. You can do either one first, and you don't need to wait. One right after the other. Don't forget the sock method for the CYA. You don't want CYA granules in the filter in case you need to backwash before its all dissolved.
    Apr 2014
    louisville,ky
    37
    So I wanna bring CYA to 40 and my chlorine to 4?
    Richard320's Avatar
    Jan 2010
    19,049
    Sure. Both are decent targets. You'll need to pay attention to the FC level and possibly target a bit higher if it dips below the minimum for your CYA every day.
