Hello!
I have a Jandy VSflopro, and just replaced my filters. I've had the pool for years, and generally can replace filters with no problem. This time, I started the pump, and it read that it was priming, then went up to full speed with no suction. The pump basket remained free of water, but the pump didn't get hot. After several minutes, (about 5) of running at full speed with no pressure, I heard a beep and then the pump stopped. It reads that it is on, but there is no sound, and nothing is happening.
I tried turning everything off and back on, and that didn't work. I also flipped all the breakers to reboot the system, and still nothing. It is a self priming pump, and I generally don't have to add water after a restart, but it does take longer to get pressure than when it has just been off for the night without opening any of the equipment.
Any suggestions? I can provide more info if needed.
Thanks so much for your help!
