Results 1 to 14 of 14
Thread: TFP testimonial
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    TFP testimonial
    Well I have been on the tfp method for many months and things are crystal clear and balanced. My daily cost is about .25 cents for chemicals versus $2.17 a day with the Frog. Plus my pool is cleaner than ever without shock, algaecide, or metal mineral packs. My cya is coming down slowly. After converting to a Borate pool my ph and Ta are staying smooth without the wild swings. Thank you everyone for all the advice.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Re: TFP testimonial
    Having your own test kit makes a difference, huh?
    Now that you've got this chemistry thing figured, you can start answering questions.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: TFP testimonial
    It makes an enormous difference
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: TFP testimonial
    Nice work!
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,186
    Re: TFP testimonial
    Richard has the right idea, it's starting to get busy in here - jump in and answer questions......
    Support the site
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: TFP testimonial
    Will do
    j_m_min's Avatar
    Feb 2015
    Houston, TX
    47
    Re: TFP testimonial
    25 cents a day?
    1/12 of a gallon of bleach a day? My pool is twice your size and take 1/2 gallon of bleach a day, so about $1.50 per day for bleach.
    How are you keeping you FC up for such a cheap price?
    25,000 IG plaster pool. DE Pentair 60 gallons. Hayward pump with Single speed AO Smith 2.4 hp motor. Pool installed probably 20 yrs ago. Taylor water tesing kit.
    Casey's Avatar
    SW PA
    10,448
    Re: TFP testimonial
    Good for you. It's so much easier and looks better!
    Aug 2008
    Fredericksburg, VA
    51
    Re: TFP testimonial
    We've been using the TFP method for a few years now and we couldn't be happier. We just opened our pool on Friday (5/8), and by the next day, the water was clear. It used to take days for the water to clear up after opening. Today's FC level was good, 0 CC and if tonight's chlorine loss test passes, I'll stop slamming tomorrow.
    This really is the only way to maintain a pool.
    20,000 gal. free-form plaster on concrete
    Triton DE filter, 1.5HP pump
    Aquabot Elite pool cleaner
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: TFP testimonial
    Quote Originally Posted by j_m_min View Post
    25 cents a day?
    I get bleach at Food Lion $2.50 a gallon. My current usage is 10 to 12 ounces a day.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: TFP testimonial
    Knowledge is power. Power to take control of your pool and not blindly hope it will be ok. I love hearing this from people. Excellent!!
    Essential Links:
    DFW, TX
    24,497
    Re: TFP testimonial
    Hey, flipflop swiped my user name before I even got here! I like a flipflop.
    Re: TFP testimonial
    Three years ago I was in tears and ready to fill in my in ground pool with cement-TFP walked me through the whole process of clearing up my "difficult pool" (that's the term the pool stored used ). I had added so many chemicals that my CYA was off the charts-the pool store never even mentioned checking that level-just kept selling me more chemicals-I was leaving the store many days with $200 of chemicals, all while my pool got cloudier. Today I opened up my pool after a loooong Chicago winter and my pool is crystal clear. My levels are near perfect- if it ever warms up here, we're all set! If any one wonders if TCF is worth the time it takes to educate yourself and try the method, my advise is not to waste another minute. When I first started reading this forum I thought I'd never get it right-but it's very easy!
    THANKS TFP!!
    Kris
    In ground 26,000 gal. 16x36 Avg depth-6'
    sand filter used 24/7
    auto cover
    Elgin/Illinois
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Re: TFP testimonial
    When I finally got a house with a pool, this was the first place I came to even before the paper work was signed.
    And I had a TF-100 kit delivered to work 2 weeks before I moved in.
    There were tabs in the skimmer, dangerously low ph (unswimmable eye burn levels) and high CH and 300+ CYA.
    The previous owner "showed" me how to backwash without bothering to rinse and when I asked about
    the sand shooting in from the returns he said that was normal. haha.
    keeping the pool nice and blue (avatar pic is from first swim last saturday) from day one thanks to the forum.
    Dolphin E10 Cleaning Robot.
