Results 1 to 7 of 7
Thread: Blank LCD on SP3400VSP Pump
    May 2015
    Oldsmar, FL
    3
    I noticed my SP3400VSP did not start up this morning. I examine the pump and there appears to be power on the LCD display but the screen is completely blank.
    I have powered off the breakers and powered back with no luck.
    Has anyone encountered this issue before on a Hayward SP3400VSP?
    Is there some combination of buttons that can reset the unit?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Blank LCD on SP3400VSP Pump
    Hi, welcome to TFP.
    Hopefully someone will be along soon to help.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Have you verified that there is power to the pump (i.e. measured with a volt meter)?
    Is the pump drive on surge protection and did you change that?
    Any power outages recently?
    Mark
    May 2015
    Oldsmar, FL
    3
    Quote Originally Posted by mas985 View Post
    Yes, this is occurring when we get outages during Florida thunderstorms.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Is the pump on surge protection?
    Mark
    May 2015
    Oldsmar, FL
    3
    No, it is not currently.
    mas985's Avatar
    Pleasanton, CA
    11,737
    It sounds like the drive fried during the storm. One of the downsides of a VS pump is that they are susceptible to power surges.
    However, you may want to double check the power going to the pump to make sure it is getting power.
    Mark
