Thread: New pump help
    Feb 2015
    Cypress, TX
    54
    New pump help
    I had start up yesterday on my new pool and everything was fine until yesterday evening when the pump started making a loud noise. It hasn't stopped since. When the pump is running at higher Rpms it drowns out the noise slightly but at low rpm it is nasty sounding. Any ideas what it is? I videoed the noise here.
    https://vimeo.com/126676643
    Pb is sending someone out Monday but if it's something simple I don't mind trying to take care of it. This is a pentair intelliflo 3 hp vs pump.
    18k gallon IG gunite/pebblesheen with 3ton moss rock waterfall, 8 ft 12" raised wall & rock accents , 42sq ft 12" raised spa w/ 6 jets & cascading stacked stone waterfall, 3HP Intellifo VS pump,
    420sq ft Pentair cartridge filter, 400,000 BTU Pentair Gas Heater, 1.5HP Whisperflo water feature pump, 1.5HP Silencer Spa Blower, 3 intellibrite lights, EZTouch System 8
    Mod Squad pooldv's Avatar
    DFW, TX
    24,495
    Re: New pump help
    I can't listen to the video right now. But, last weekend my pump (same one) was making a racket. Turned out to be a snail under the rear cover in the fan.
    Feb 2015
    Cypress, TX
    54
    Re: New pump help
    Pb thinks something go to impeller. They are going to fix Monday.
