Results 1 to 10 of 10
Thread: Help removing a loop loc cover
    Aug 2011
    Northville, Mi
    312
    My cover is solid with a mesh strip down the middle. Never removed it myself so I'm kinda dumb here...
    First question...how exactly do I remove it?? I mean it's strung all tight between the anchors. Do I pull an anchor completely on one side first? Or do I pry the hook off the anchor? Too tight to try to loosen straps and I'm guessing I wouldn't want to anyway.
    Also...how the heck are you supposed to fold it again? I've seen some detailed descriptions here that I wasn't quite visualizing. But it's just a fanfold or accordion fold, right?
    15,400 gal, 16x32 vinyl rectangle (sport dig), Intelliflo VS, 240 sqft cartridge filter, Intellichlor IC40, Mastertemp 250, Dolphin supreme M4 cleaning, Pentair EasyTouch4, Tested regularly and accurately with supplies from tftestkits
    Re: Help removing a loop loc cover
    First, get all debris and water off the cover. Ignore water for a mesh cover. Then pop all the springs off with the provided tool. Finally accordion fold the cover at one of the short ends of the pool.
    There are several good videos on YouTube, for example:
    Aug 2011
    Northville, Mi
    312
    Um... Provided tool? All I have is the giant Allen key to use on the anchors. Is there something else I should have and, since I apparently don't, is there anything I can use as a substitute?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    If you don't happen to have the cover removal tool, you can order one through various online sites or in a pinch, a bicycle seat with the right size post will fit over the anchor and inside the loop for removal. I take no responsibility if the bicycle seat post is too thin/weak and is damaged in the process!
    Isolated Spa - 345 Gallons
    Watch the video, he shows what the tool looks like and how to kick the straps off the anchor if you don't have the tool.
    Aug 2011
    Northville, Mi
    312
    Omigod! I found the tool but what a workout! Do these come in different sizes? Mine is smaller than the loop so the neat and perfect twist he does doesn't happen! I'm already exhausted after 8 and I have 22 more to go! Do these things come in different sizes?
    May 2013
    Long Island NY
    419
    You need to develope a technique for using the tool. It make take you a few tries but basically when I do it I place the tool over the brass screw, give it a twist to get between the screw and strap ring and a swift kick and they pop right off.
    Sorry, I know that makes no sense but once you figure it out, it will. Just using arm force will kick your butt like you described.
    Mine don't pop off easy like the video either. They need a swift kick on the tool and my spring are set per Loop loc instructions. His looked easy.
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    Aug 2011
    Northville, Mi
    312
    Heel of the shoe for the other 22. Now I'm drying the cover. things heavy as heck!
    Aug 2011
    Northville, Mi
    312
    Incidentally...big shout out to all you wonderful pool geeks here! Pic below is just after the cover's off. Levels:
    Cl - 0.5
    CYA - 50
    pH - 7.4
    TA - 60
    I couldn't be happier!!
