Thread: Spa aeration: pH rise... Natural equalisation?
    Daf-Tekno's Avatar
    Sep 2014
    Calgary / AB
    70
    Hi TFPers,
    I was thinking today:
    1. If, in a Spa, aeration is commonplace
    2. and such raises pH
    would a happily-balanced Spa's pH naturally settled back down to its original lower pH if left alone for a set length of time,
    or are we Spa owners always required to add Muriatic Acid / powdered equivalent on a regular basis to keep pH in check?
    It just feels like I'm constantly fighting something as I keep having to add acid to the water.
    Maybe it's just part of the job...
    Thanks - D
    Jacuzzi J480 (2008) 1700 litres, Balboa ozonator, Delta EZ-18-120 UV lamp via custom 6-way 2-tier timer solenoid array, 2 x Waterway 4HP main pumps,
    1 x Aqua-Flow 1/15 HP circ pump, ChlorMaker IL SWG, SmartSeal + Roxul skirting insulation, 8' x 8' ThermoFloat Spa blanket, 100" x 100" Gator coverall
    jojoman's Avatar
    Jun 2014
    Mandeville,La
    185
    Re: Spa aeration: pH rise... Natural equalisation?
    I don't think it will go down by it's self if that's what your asking.
    12K gal, custom flipped kidney bean with spillover spa. All Pentair equipment, Whisperflo 1 1/2 HP, 400K BTU heater, Intellichlor IC 40 SWG, CCP-320 Cartridge filters, Kreepy Krauly pool cleaner with bootster pump, QuartzScapes in Aruba Sky blue, LED lights and travertine tiles for decking and stones on rear edge for landscaping. TF-100 test kit w/ SpeedStir
    For a standalone spa, you lower the TA until the PH is stable.
    Once the PH has gone up, it will not go down again without adding chemicals.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Here is a hot tub care article with a fairly in depth discussion of PH.
    http://www.troublefreepool.com/threa...-Spa-(or-pool)
