Thread: Cold water entering Spa after heater turned off
    I know I skipped a step.. After heating the spa... then turning it off make the jets shoot out COLD water? What did I forget to do?
    Helen
    Dallas Area, 16,000 gal IG, Easytouch 8 computer, Intelliflo 3HP Variable Speed pool pump, Pentair Smart Pump 4x160, Pentair 3/4 HP Booster Pump, FNS 60 DE 60, Mastertemp 400, Rainbow 320, Dual Timer w/ freeze protection, Intellichor SWG, TF100 Test Kit, POOL FILLED AUG 3, 2012, ORDER YOUR TF100 KIT FROM http://tftestkits.net
    http://www.troublefreepool.com/under...ie-t49936.html
    Re: Cold water entering Spa after heater turned off
    When in spa mode you want the suction port set to come 100% from the spa. If you accidentally draw any water from the pool the jets will be cold.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Yeah, when heating the spa, you don't want to see any spillover to the pool.
    The last time I had a bunch of people over to swim, the spa was a lot warmer than the pool and as the sun went down, the kids gravitated towards the spa. When they didn't want to get out, I just killed the heat and moved the valves and chilled them out.
