Results 1 to 9 of 9
Thread: Which heat pump
    Ga mike's Avatar
    Mar 2014
    Georgia
    85
    Which heat pump
    Hey everyone! I have a very large pool (40-45k)that is in sun most of the day. Looking at getting a heat pump heater. Need pros and cons on different ones. Which ones work best, etc. Thanks in advance!
    20x45x32x18 L Shaped vinyl Pool
    Pentair Superflo 1.5 vs pump
    Pentair t100 filter
    I 60 cell
    Ga mike's Avatar
    Mar 2014
    Georgia
    85
    Re: Which heat pump
    Meant to put in everything else. Sorry
    Pentair t100 filter
    I 60 cell
    Jul 2007
    Suwanee, GA
    528
    Re: Which heat pump
    Do you have a cover? I had a heat pump for many years and it took a long time to heat our 21k pool (no cover). I switched to gas.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
    Ga mike's Avatar
    Mar 2014
    Georgia
    85
    Re: Which heat pump
    I don't have access to gas. Was looking at 133k raypak. Cover is no problem. Just trying to get a couple more months use out of pool. Kids swim when water hits mid 70's. Too cold for me. Lol
    Pentair t100 filter
    I 60 cell
    May 2009
    Youngsville NC
    395
    Re: Which heat pump
    Quote Originally Posted by Ga mike View Post
    You got access to gas - propane. That said, at the price of propane - I understand why you're looking at heatpumps. I want one myself. And I'll swim when the water is 72
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
    Ga mike's Avatar
    Mar 2014
    Georgia
    85
    Re: Which heat pump
    Exactly why I'm looking at heat pump.
    Pentair t100 filter
    I 60 cell
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Which heat pump
    Propane is the most expensive option to operate. It is a lot more than gas. Solar panels are the cheapest to operate if you have a good sunny southern exposure. Heat pump is cheaper than gas to operate, but slow to heat. If you are looking to maintain a steady temp or heat a couple of days for weekend swims it will work. The climate in GA is probably good for a heat pump. Especially using a cover. I would get a big one, you have a big pool. 140k btu or thereabouts.
    I would get Pentair because that is what you already have and they make good stuff. You could get a Suntouch down down the road if you wanted some automation, especially if you decided to add solar too. It could control heat pump, solar, IC60 and the pump.
    Ga mike's Avatar
    Mar 2014
    Georgia
    85
    Re: Which heat pump
    Have really thought about solar on top of the pool pavilion. I only have a 1-1/2 horse super flow vs pump. It has done a great job so far. What are some good brands of solar and who to stay away from?
    Pentair t100 filter
    I 60 cell
    DFW, TX
    24,450
    Re: Which heat pump
    We have 5 Vortex panels from solardirect.com. We are pretty happy with them. They have kept our pool pretty much at or slightly above the high temp this spring. And this spring has been tough because of all the rain. Rain makes a pool cold faster than anything. Solar controller is a must. There are some pics of our solar in my build thread in sig.
