Results 1 to 15 of 15
Thread: Total cost to open pool about $3.50 - Thanks TFP
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    People really don't believe me when I tell them how little I spend to run my pool. I opened it up tonight. Here's two pics when the cover was just removed. Pretty clear and easy to see main drains.
    After checking water, I found the following:
    FC: 3
    CC: 0
    pH: 7.2
    TA: 70
    CH: 170
    CYA: Not tested due to low light
    Salt: 3300 (per system, not test)
    Water temp: 49
    My CYA should be close to where I left it or lower since so about 15" of water was drained in fall and added from snowfall and rain. I figure it's around 60, It was 70-80 when I closed. That being said, I figured a little extra bleach was ok since it was just getting opened and SWG is off due to water temp.
    So one gallon of bleach: $2.93
    About 30 oz of washing soda: Maybe 50 cents?
    Probably could have left the pH alone too, but figured I'd get it around 7.5.
    New readings after a couple of hours:
    FC: 6.5
    CC: 0
    pH: 7.5
    TA: 70
    CH: 170
    Water temp: 48
    Seriously TFP, $3.50 to get the pool balanced, in one day...Thank you!
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    Re: Total cost to open pool about $3.50 - Thanks TFP
    Support the site
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Divin Dave,
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Nice work! Next year shoot for under 3 bucks!
    Casey's Avatar
    SW PA
    10,444
    Don't be surprised if you lost CYA over the winter. It happens.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Nice Job Steve. People never believe it, it's a common problem with TFP. No mystery to pool care at all.
    I like your Dog by the way...been meaning to say that.
    Essential Links:
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    I'll be testing that today Casey. I might have. I'll report back on that.
    Did an OCLT too, and this morning, same, 6.5. No loss. Nice! Now just for it to warm up...
    Stupid Polaris 280 though, won't get into the shallow end. Starting doing this last year. Need to research that...I tried thrust adjustment, and that doesn't seem to help much. The hose seems to have some bend memory now, so I wonder if that's contributing to it.
    As for my dog, yeah, that's Marcy. She's my baby. She's a terrier mix, mostly Rat Terrier from what we can tell. From Arkansas. A rescue dog. She's an absolute peach, and knows she's got it good now!
    Thats awesome...I'm going to open my pool in the next few weeks and hope it goes as smoothly as yours did!
    IG freeform gunite w/attached spa. Purex Triton FNS Plus 60 filter with matching multiport backwash valve. Century 1.5HP motor. Purex Minimax Plus 400 gas heater.
    DFW, TX
    24,485
    Rat terriers are really good dogs.
    May 2014
    Jackson, TN
    11
    Just opened this weekend (Posted a thank you on this forum) Clean water and tonight just tested the full test: After adding 1 gallon of bleach, FC is 6, TA 70, CYA (added about 1/2 cup) 41, pH 6.8. Gonna bring my pH up a little with borax and do a second big vacuuming (mostly from the pollen falling from the elm trees) and..... well, that's it! Ta Da! swimmable pool!
    Intex Ultraframe AG 18 x 52, 6981 gal, 1,600 gph sand filter,
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    Sounds like you're in the $5 range to open yourself. A really great feeling isn't it?
    30,419
    Nice post, Steve. I was speaking with a moderator the other day and we both remarked how VERY rewarding it is to see these stories posted on the forum. Thank you for sharing your ongoing story.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Great job..
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    I'm trying to convert a coworker who had a pool put in last year. He said he just paid $300+ to have his pool opened, and that would be the last time he would do that. I told him it would probably cost $6-9 to open it himself; just the price of a little bleach. We got talking test kits, and my foreman mentioned something about a better test kit. My coworker asked me about the Taylor 2006 on Amazon. I pointed him to tftestkits. He ordered a kit and salt strips last night. Not sure where from though. Hopefully he'll join the better side fully, and not just dabble.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Plano, TX
    20,000 gallons Kidney Bean IG Plaster, Pentair Clean and Clear 530 Cartridge Filter
