Thread: Water Scale
    Jun 2013
    Seguin TX
    192
    Water Scale
    Question
    Recently finished a slam on the pool, check my sig below for specs.
    The water is clear, but if you run your hand under the waterline and over the walls of the pool there is some sort of scaly white substance on the pool walls, it feels rough to the touch and when it flakes off it looks like soap powder flakes.
    FC and PH are all within norms, what should I test for? and what is this substance?
    Thanks
    2017-Intex Ultra Frame 16x48 5000 Gallons
    Intex 2800GPH Pump with 14" Intex Sand Filter
    My Intex Pool Setup Video :Intex pool rises from the ashes - installing and leveling - EP-72 - YouTube
    Re: Water Scale
    Can you provide a full set of test results? It sounds like calcium carbonate scale.
    It could be high csi or due to adding certain chemicals too close together in time.
    Can you list all chemicals you have used and how you added them.?
    Support the site
    Jun 2013
    Seguin TX
    192
    Re: Water Scale
    Bleach-CYA that is all. I will test everything and post some results our water here is very hard, but we have had lots of rain and I have never seen this before on the inside walls of the pool.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: Water Scale
    Sounds like Calcium Scale. And if it flakes off, you should be loving life. If you could get that stuff off the walls and vacuum it to waste, it would a cause for celebration. Keep the pH on the low end of swimmable and it should dissolve back into solution.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Water Scale
    Numbers please, we really need them to answer on a possible scaling issue.
    Essential Links:
