Thread: Amerlite Niche LED Upgrade
    May 2015
    kingston springs, tn
    102
    I have a 10 year old Amerlite Niche and would like to upgrade to an LED 12v Bulb. Pentair recommends the following -
    I can handle the 12V wiring that is no problem. My question is how difficult is it to replace the bulb with water in the pool. I understand the bulb is kept cool with the water. If that is the case why do you need to replace the gasket unless that keeps the water out. Any advice is much appreciated.
    I just don't want my pool to start leaking from replacing the bulb.....
    Quantity 1 – Pentair 602060 Amerlite 12V Color LED Lamp
    Quantity 1- Pentair 79101601Z Lens Gasket Replacement Kit AmerLite Pool and Spa Light
    Quantity 1 – Intermatic Pool and Spa Fountain PX300 Light Transformer
    Mar 2011
    441
    Re: Amerlite Niche LED Upgrade
    Is the existing fixture 12v or 120v?
    20X40 30,000 gallon gunite pool
    Jan 2013
    Cleveland, OH
    70
    The water keeps the fixture as a whole cool; the bulb is sealed inside the fixture (hence the gasket). The bulb itself does not come in contact with the water
    20K gal, vinyl, 1 HP Challenger 2-spd pump, 300 lb sand filter, Raypak 266K BTU, 45M stenner pumpin' bleach
    May 2015
    102
    Quote Originally Posted by racket View Post
    Existing is 120v. I plan to install the intermatic px300 transformer.
    Mar 2011
    441
    Quote Originally Posted by pondfishr View Post
    If you just have one light a px100 will be enough.
    May 2015
    102
    Yes you are correct, I believe the light draws around 35 - 36 watts. The 300 is overkill... But for the small price difference we have the option to add additional low voltage lighting around the pool later.
