Thread: POOL Calculator
    POOL Calculator
    Hi, i'm trying to learn a little bit more about how to work with the pool calculator.
    How do i make it so that my goal numbers stay the same everytime i log on? Can i personalize my settings? (Salt level, desired PH, as an ex if i want my PH a little different than the given, or gallons to stay the same).
    When changing DESIRED goal readings, can i set it so that when i log on, these numbers will not change.
    18K gallon IG pool and separate 1200 Gallon IG spa - Both have: Diamond Brite Plaster- Hayward DE Filter -Propane heater- renovated 8/2008
    Re: POOL Calculator
    If your web browser supports and is configured to allow cookies, any numbers entered into the Goal column will remain the same when you come back to the page. If cookies are disabled for some reason then the numbers will go back to their defaults each time.
