Results 1 to 7 of 7
Thread: Away From The Pool For 10 Days
    I'll be away from home for 10 days in the near future and won't have anyone to manage the pool. I've been successfully using the TPFC method for almost 2 years, but will need to use the dreaded dichlor/trichlor pucks while I'm gone, so this is more of a question regarding product.
    Many here have recommended bringing the FC up to shock level then running a floater, so that's my plan. My current CYA is more than 30 and less than 40 (I can't be anymore precise), so I figure I can weather the extra CYA.
    I'm thinking with trichlor, I'll get a bit less CYA than if I use dichlor pukes... err pucks. Leslie's sells a 7lb bucket (Mighty Tabs) for $70 whereas Walmart sells a 10lb bucket for about $40. Both claim to be 99% Trichloro-s-triazinetrione. Considering I have no intention of using these things more than the week and a half that I'm gone, the cheaper the better, but is there anything to worry about regarding the Walmart product? No arsenic or lead or uranium 232 that the Walmart brand might add as a special ingredient?
    14,000 Gal IG Pool/500 Gal Attached Spa
    Pentair Whisperflow 1hp Single Speed Pump
    Sta-Rite Posi-Flo PTM-135 Cartridge Filter
    Hayward H400 Natural Gas Heater
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,505
    Re: Away From The Pool For 10 Days
    I use the ones from Walmart when I leave for the weekend. I have not had any problems with them. They are good to have on hand for such times. Just keep them in a cool, dry place.
    I just want to add that they are okay to use so long as you are aware of what they are adding to your pool just like you stated in your post. They are another tool in your tool box for the pool.
    Kim
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,002
    Raise the water level way up before you go. You don't want a heat wave or a windstorm to evaporate it down to where you suck air and lose prime while you're gone.
    kimkats and Richard... all excellent advice. Thank you.
    30,419
    You are a TFPC seasoned! You understand what to do and why you are doing it. Very nice. You will likely return to a pristine pool.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    As long as you make sure the tablets do not contain copper you should be fine. Some of the Walmart brands contain copper.
    Love TFP? Become a
    TFP Supporter!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,492
    Good work! I bet if you added a little uranium232 to your pool you wouldn't have any algae ever!
